Our duet is a similar model # to yours (GEW925) and we have the same problems. Sometimes the various settings work and sometimes they do not. Sometimes the dryer does not want to come on at all, but will eventually work on some settings. I cannot change the temperature setting - it just beeps at me! The dryer will sometimes just start up when I am trying to get it to go to a particular setting and have not yet pressed the start button. Does anyone know whether this can be fixed without having to call in a technician.
The only thing you can do is replace the user interface on you unit. It has an intermittent sticking button on it. If you accidentally dislodge this mysterious bad button, it will work temporarily. You can go to www.sears.com and click parts direct. Enter your model number and click the control panel category. You will need the user interface board and not the main control. I hope this helps you out.
is just one example, but you might be able to find a better deal by shopping around. These guys will let you return it if it turns out that it didn't fix the issue. Also, when you shop around, be sure to use the complete model number on the sticker inside the door of the unit. There are many different versions of the same model out there- every year Appliance companies come up with a new button to add and one to take away, so if you don't have the complete model number, the part may not fit.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#!#!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$#@
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches. (Tip Courtesy JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$#$#$
