I have unplugged. PUshed power button 30 sec. PLugged back in, still wont come on. THere is a message in bottom right corner of tablet that also says Windows8 is off. CAn you help?
SOURCE: wont charge
It could be that your battery is defective/worn out. If the computer just shuts off immediately (doesnt try to hibernate/standby) then you're likely looking at replacing the battery. They can suddenly do things like this if a cell shorts out in the battery or due to common wear. But first, here are a couple of things you can try.
1. Try reseating the battery (pull it out and put it back in). Sometimes something that simple can fix the problem.
2. Try to calibrate the battery. Your computer may come with instructions on how to do this, but if not you can do it manually. Turn the computer on but go into BIOS (press F10 at the compaq logo screen). Don't load your operating system
Unplug your computer. If it turns off at this point, your battery is already toasted. Replace it.
If the computer keeps running, let it go until it finally shuts off due to battery drain. Then plug it back in and let it recharge completely. This will let the microchip in the battery learn its charge potential and may allow you to get more life out of it.
Note: Calibrating these batteries is good practice but it shouldn't be done very often. If your calibration doesn't work after 1 or 2 tries, you probably still are looking at a dead battery.
SOURCE: acer laptop wont turn on has power button light up
This is a common problem with Acer units, both desktop and laptop. The motherboard fails to read the system BIOS at startup. Removing the battery from a laptop merely removes the power source, but not the stored memory. If you are able to locate the CMOS battery, or the cell battery the size of a US quarter dollar, that is the system battery. Remove that, wipe with a lint free cloth (coffee filter) then replace.
If that effort fails upon replacing the cleaned CMOS battery and laptop eneregy source, then a new coin cell may be the solution.
If a new coin cell fails to resolve the problem, the motherboard itself is the culprit. Time for a new laptop or desktop.
Hope this helps you...
SOURCE: Epson R320 Service required message
SSC will not reset the R320
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank
SOURCE: Base handset out of range
Try opening the phone battery compartment on the back of the phone, disconnecting the battery wire, then reconnecting the battery wire. Solved my "Out of Range" problem - phone came back on and worked properly.
SOURCE: computer wont stay on once power button is pushed
yes unfortunately with this series of laptops it is VERY common for the motherboard to fail because of something called an NVIDIA chipset so if you are not hearing any fans or hard drive activity for more than 3 to 5 sec than im sorry to say that this is what it is but you can however get new motherboards on ebay for a fair price! i am sorry and i wish you the best of luck.
