Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
1994 900s saab
Sometimes will start, then wont. replaced starter--that wasbt the problem. battery tested that wasnt the problem. could it be the ignition switch
  • Al Klein
    Al Klein May 11, 2010
    It depends. Does the engine turn over and not catch, or does it not turn over?
    Scholar:
  • 56 Answers
You could have a high resistance issue.
Corrosion around the battery terminals and corroded fusable link could be your problem. A loose terminal clamp could be a problem as well. Testing the battery and having a decent charge, might pass, but if you have corrosion, then the "decent charge" will not get to the charger, or maybe only slightly. This corrosion will cause the engine to turn over slowly aswell.
Also check that you have spark going in to your Cylinders, aswell as fuel. An easy way to check if fuel is pumping is by turning the car to run and listening for the fuel pump "whine". Or you could find your fuel test port over the engine, it is a rail with a port with a green cap, depress it with a pen and you will get a squirt of fuel. Becareful and wear nitrile gloves.
https://w05.dealerconnect.chrysler.com/service/mds2002/serviceInfo/en_US/80468d30.gif
Posted on Jul 22, 2009
Ignition switch
check your battery for some dirts and muds then clean it with wter. also check for some open wires that has a contact to the body of your car. also check if the bendix drive of yor starter is still ok.
Jan 27, 2012 | 1997 Saab 900
My car wont start and it has a clicking sound.. alternator is good.. battery is good.. we even tried direct start and it still wont start
I would take the battery out and down to the auto parts store and have it checked under a load,it may seem to be ok because it can operate the lights and such but if it has a couple bad cells it will cause the problems that your are talking about,such as not being able to jump start from another car.Star with a complete test of the battery and then check your battery cables next..
Jun 24, 2011 | 2004 Saab 9-3
1999 saab 9-5 4 cyl 1600234 miles regular oil changes (mobil 1 synth) my wife was coming home check engin and gear box lights came on she got home , now car wont start. i checked throttle,not in limp...
Check the battery and the Alternator. Sometimes with these Saabs, when the alternator or the battery start to go bad, you will have many different symptoms all to do with just one issue. You can remove the battery and the alternator, take it to a parts store and they do free testing on those and they can tell you if either is bad or not. The Alternator needs to be out of the vehicle to be tested.
Jun 17, 2011 | Saab 9 5 Cars & Trucks
2003 saab 9-3my car wont start, i hear 1 click and that's it. if i push it ,it will start
sounds like a bad starter. Remove starter and have it tested at your local parts chain. Please let me know if you have more questions, and thanks for using FixYa.
Mar 19, 2011 | 2003 Saab 9-3
Have a 2004 saab aero 9-3. Recently battery died. It was shorted. But 6 years old. Replaced battery. Now often when trying to start, makes one loud click and won't start. Displays flicker and/or go black,...
I was having the same problem with my 2004 9-3. I assumed the starter was bad and replaced it. I then charged the battery and found it wouldn't fully charge. After charging for several hours when I removed the charger I only showed 11 volts at battery posts. The new battery tested 12.8 volts and the car started well. With the car idling I tested and showed 14.6 volts at the battery post which confirmed my alternator was charging.
I do believe I replaced the starter in error and that it was just a bad battery. When my battery was failing I had dim headlights and flashing displays that you described and the clicking noises also. When I put jumper cables on my saab and let the bad battery charge for several minutes the car would start right up and the headlights would brighten up and even though the battery was bad the idle voltage at the battery posts was increased to 14.6 volts coming from the alternator.
Remember to remove the jumper cables quickly once the car starts to avoid possible electrical problems.
I have had bad starters in other vehicles that would draw a huge load on the battery and jump starting them would sometimes give enough voltage to turn the engine over and start it.
Bench tests aren't always correct because the components aren't under a true load. I had a brand new alternator fresh out of the box last year that was bad and wouldn't put out good voltage even though it bench tested perfect. Go figure.
Check your battery voltage with the engine off. It should read over 12 volts if its charged.
Sep 05, 2010 | Saab 9 3 Cars & Trucks
I have a 04' saab 9-3 areo sometimes it wont start just a clicking noise (like when you have a low battery) but i have had the battery Alternator and starter checked all good.If i keep the key in the...
Sounds like a bad starter relay. When you turn your key to start, current flows through a relay which in turns supplies 12 volts to the solenoid on your starter motor. As you alluded to , typically the common clicking sound that we all hear occasionally, is usually related to a flat battery or bad starter motor, but as you have had these checked (by a professional?) the only possibility is the relay that supplies 12 volts DC to your starter motor solenoid.
Thought you might find this interesting to help you understand ignition systems:
http://auto.howstuffworks.com/ignition-system.htm
Cheers,
Steve (Melbourne, Australia)
May 14, 2010 | 2004 Saab 9-3
In snd out of it
Check your battery cables and terminals. If they are ok, check your altenator because it might not be charging the battery properly.
Jul 22, 2009 | 1994 Saab 900
Car wont start...sometimes
Sounds like a bad starter solenoid, usually cheapest and easiest to replace the starter and solenoid as a unit. It is always best to check for power between the solenoid and the starter with a test light, if the solenoid clicks but the test light doesn't light up you have found the problem in the solenoid.
Apr 28, 2009 | 2003 Pontiac Grand Am
9000 won't start!
Sounds like a crank sensor. They can drive you mad. If you hear a clicking sound when you try to start it, that is the battery. But if you turn the key it starts, you drive some place turn off the car for 5 minutes and then try to restart it, and it does nothing at all, that is a classic crank sensor.
Dec 08, 2008 | 1988 Saab 900
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
91 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
