Question about Dometic Rooftop RV Air Conditioner
Ac fan not working
My ac comperssor and my fan won't come on. It works when I push the switch on the coil. The guy at the shop said that I was losing power and that the unit is being grounded somewhere. How do I fix this?k
  • 22 Answers
Replace that switch on the coil that you are pushing. If the unit was going to ground when you pushed that switch two things would happen it would spark and then flip the breaker. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
My ac blower works on high but then it turns the ac switch off if you turn it to 1,2,3, the ac light come on but the blower does&#39;nt work i put a new blower motor in three weeks ago
Often in cars there are a couple resistance wire coils in series with the slower fan speeds, and these resistance wire coils are usually in the air stream inside the air ducts in the dashboard. As they corrode(they are in the airstream) and age sometimes they overheat and burn out and stop the blower from lower speeds. Needs be found and replaced if "Open circuited" A wiring diagram from the manufacturer would reveal. If "blower resistance coils" asked for at autoparts store (used by garage auto repair guys) may have a parts lookup, assembly schematics may show where it is located in the vehicle.
Sep 26, 2014 | Mazda 2003 MPV LX
Why does moter blower wire from ac gets hot ?
motor is probly old and drawin tumuch currant--or wire has alota resistence or corrosion-------if u dont git this fixd then the ac fan switch will soon burn out--replacin motor is not easy-need a shop book and take the dash out--inspect heater core and ac evaporator while in there to save $$--old car-----enjoy
Jun 16, 2014 | 1988 Oldsmobile Delta 88
Honda element ac
1.check the ac fuse. 2.might be that you have a leak in the piping system and there is no gas for the ac to run. 3.the comperssor might be faulty
Jan 18, 2014 | Cars & Trucks
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My heater/ac fan sometimes won't work. What do I check first?
$24the AC light does not light until you turn the fan on, that is ok, the issue with your fan only working sometimes is more than likely a faulty blower motor, in some cases it is the switch, when the motor does not turn on try tapping it and see if that makes it work, if it does then it is the motor.
the switch at autozone is part number SW295 and is $16
the motor at autozone with the blower wheel is part number PM136
cost is $24
Sep 29, 2012 | 1998 Pontiac Grand Prix
I had auto shop put freon in and then they said was working fine...said pay and you can go, car cooling just fine...I go out to my car and complete system is dead. The fan controls in dash now dead....
If your system its empty of free on, yow wont be able to activate your ac compressor, you might have a leak some where, this its the simple answer, there could be more problems, a bad blower motor, relays, fuses, cloged system, etc.:)
Sep 17, 2012 | 1999 Jeep Cherokee
My 2003 vw bug dies and won"t start when i run the ac on very hot days. sometimes when i"m driving all the instrument panel lights all come on ant then it loses power to aprox 5 mph. I checked the...
ENGINE GETTING TOO HOT AC PUTS MORE LOAD ON ENGINE AND OUT SIDE TEMPERATURE HOT.YOUR CAR TELLING YOU I AM HOT AND NEED A BREAK.MAKE SURE COOLANT LEVEL NOT LOW AND THE COOLING FANS RUNNING WHEN AC GOING IF NOT CHECK FAN FUSE IF FUSE GOOD.YOUR THERMO SWITCH NOT WORKING OR THE COOLANT TEMPERATURE SENSOR AND FAN CONTROL MODULE COULD BE THE PROBLEM IF THE FANS DONT TURN ON.
Jul 15, 2010 | 2001 Volkswagen Beetle
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Dodge Ram AC not blowing cold
By pass both pressure switches one at a time with small wire or a paper clip. If comperssor kicks on replace the swich that you bypassed.
if not it could be the fan clutch ot the compressor. Compressor runs about $400.00
Jun 15, 2009 | 2000 Dodge Ram 1500 Truck
95 Saab 900
If the low speed fan doesn't come on, but the system works when cooling air is blown through it, that says that whatever temperature sensor is used is working. It also seems that, if the fuse is OK, then the switch for the fan isn't working. There should be a switch module down there near the fan (you'd see wires from the fan to a harness, and it'll plug into a module). I'd be willing to try replacing that switch and see if it solves the problem.
Jun 20, 2008 | 1995 Saab 900
Dometic Rooftop RV Air Conditioner Logo
311 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
