SOURCE: No HDD Found on initial XP Install
Make floppy for SATA, when start instlling Windowz press F6 and this is it!
SOURCE: PROBLEM
here are some link for the error codes hope this helps.
ERROR CODE 7( NTKRNLMP.EXE) .http://support.microsoft.com/kb/812580
ERROR CODE 4 ( SETUPDD.SYS) .http://support.microsoft.com/kb/330181
SOURCE: help with a toshiba TECRA 8100
Yes, it should run WinXP. The minimum system requirements to run both Windows XP Home and Professional are 233Mhz, 64Mb RAM and 1.5GB hard drive space. I have a Toshiba Tecra 8000 that still runs XP, a little slow, but has run smoothly for 5 years.
The setupdd.sys error is most likely a due to a defective hardware like RAM. Try installing only one ram if you have two to see if either one is defective; it should work for most users.
SOURCE: gateway laptop wont recognize the disk drive
You must "setup" your new drive. You should have received a cd or floppy with the new drive. Purpose of that disk is to prepare the drive to receive information (format it, partician it, make it so it can tell the BIOS who it is and were it is located).
Do you do maintenance regularly on your drive? Clean and defragment? If not - please return your old drive to your computer. Get CClean a free download (google it). Run it to clean temp files. Also run the Registry cleaner. Next get Spy Bot - Search and destroy from www.PCWorld.com another free download. Run that to get rid of spyware. Get Regcleaner from www.comodo.com (free) and run that. and lastly, visit www.pcpitstop.com and have then do a free scan of your computer. Read their very comprehensive report. Then check your computer - run any better? No - replace the drive.
I hope this works for you ... good luck ... appreciate posivtive comments if this response pleases you
a
