Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
  • GE Master
  • 1,606 Answers
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Posted on Jul 22, 2009
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
2005 toyota sienna le - back doors won't open in cold weather
iv had a few people come in with that complaint I clean inside of door and spray seal with good 100% silicone spray and spray latches with penetrating oil
Jan 13, 2009 | 2004 Toyota Sienna
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
Kenmore dishwasher Troubleshooting
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
  • Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash.If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
  • All lights should illuminate then a diagnostic sequence will start.
  • Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
  • Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 23, 2008 | Kenmore Dishwashers
Whirlpool dishwasher
Jun 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool du1055xtpt4
Jun 21, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Clean light is blinking
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
Jun 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1100XTP vlean light blinking
May 16, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
216 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
