Should I replace the timing chain on my Saturn SL2 4 cylinder engine that has 145,000 miles on it? The car runs fine and the engine doesn't make any noise or vibrations.
at the dealer we rec them at 100k,,,,even if its not noisy or anything,it is a constant wear and tear item and the chain is no bigger or stronger than a bicycke chain,,,,they stretch and can break,and if the tensioner breaks or releases tension,its as bad as the chain breaking,either way the pistons will hit the valves and bend the valves,,,,also the timing chain guides are plastic and wear out,i would rec doing it,,,,but do the guides (2) front and rear and the chain,the tensioner,and lower crank sprocket and cam gears,,,,,if the car is in good shape and youre gonna keep it do it,,,if not,,,risk it and let it go,it may never break,,,but i would do it
