I have home with no basement (houston, tx) with interior utility room. Dryer vent goes down into foundation then toward closest exterior wall where it rises 6" and vents thru brick veneer. The dryer vent began collecting water. Amount of water extracted by wet/dry vac thru exterior opening has grown from 1/4" per month to 1/4" per week. Dryer now takes 2-3 loads to get clothes dry. How do I determine how water is entering vent pipe? I have eliminated weather and irrigation as louvered cover was sealed and water continued to collect.
  • jburtn Jul 22, 2009
    good point...we have a gas dryer. it is getting hot...and, when I **** all the water out of the vent with the wet/dry vac, the dryer does the job in 1 load...
    Possible to put some sort of insert inside the existing vent pipe (in the home's foundation) so the repair is not so invasive?
  • 3,037 Answers
Sounds like a bad heating element in the dryer if you have checked for lint in the vent which should get cleaned out easily with the water. I assuming that this is an electric dryer. A dryer whose heating element is partially or completely burned out will definitely prolong a dryer's drying time. Open up your dryer's cabinet and locate its heating element. Test the element, and if it is no longer functioning as it should, you will have to replace it. Once you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it. Let me know how this turns out.
Benjamin
Posted on Jul 22, 2009
  • Benjamin Patri
    Benjamin Patri Jul 22, 2009
    Ok, since it is gas and is heating fine then I'd bet your blower wheel is bad and isn't providing the airflow like it used to to be able to blow the lint more right to the outdoors and so needs to be replaced.
    Check the blower wheel for excessive lint build up, check that
    there isn't anything stuck to the air intake baffle inside the drum,
    (i.e. the screen on the back wall of the dryer when looking into the
    drum).
    Check blower fan for proper air flow
    Check the blower wheel for being stripped out in the middle
    Notice: this is a common problem The hole
    in the center of the blower wheel should be "D" shaped.
    These strip out
    after awhile and then spin freely on the shaft, not spinning at
    the same speed as the motor. This makes a rumbling noise and
    poor/slow air flow through the dryer.
Hyow to waterproof a basement wall...
You have to start outside.
First regrade slope of soil away from foundation. Add a drain and tile to direct water away from house.
If necessary dig down along foundation wall and add membrane.
In the basement, add a sump pump to pump out water to keep moisture out.
Clean basement wall, and add some waterproofing paint.
Jun 22, 2013 | Computers & Internet
I have noticed blue mold in my basement coming from behind the area that has wood paneling, but also around the entire edge of the floor even where the walls are concrete (both interior and exterior...
This mold is from dampness in the basement.
Often this is a result of no vapor barrier installed when the insulation is put into the walls. Moisture is allowed to seep through the walls and gets into anything, even concrete.
The other problem may be from a lack of weeping tiles outside the house.
When the contractor formed the foundation walls, he was supposed to install weeping tiles to keep moisture out from outside.
Most older houses don't have this, and I'm seeing it more and more.
I would advise contacting a general contractor and getting some advice from them. You may have to have weeping tiles installed, which consists of tearing up the ground around the foundation to do so.
Then you may have to remove the flooring and wall panels as well as the drywall to install a vapor barrier.
Good luck.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Sep 22, 2011 | Computers & Internet
Is there a way to vent a basement bathroom without cutting into the cement foundation
What is in the room above the basement bathroom?
And how large is the diameter of the vent pipe you need to run?
Do you have a maximum number of elbows, and runs of feet maximum you can't exceed?
Is the Frame wall above the foundation, accessible by going up thru the ceiling of the bathroom, and the elbowing over and into the outrside frame wall at that point?-- and then up a ways, and then out thru the outside wall?
Another possibility would be: How far to a window, or vent already in the basement?-- Could you run the piping there, and then out?
How thick is the concrete wall?-- Is it reinforced Concrete-- or just Masonry Block wall? A block wall is not as hard to get thru--
I know I asked a lot of questions-- but maybe it helps you think thru your options?
Le4t me know if I can help further.
Mack B
Jan 29, 2011 | Fantech Fans Exhaust Fan In-Line
Just bought a home and found a wall wet, took tile off and the foundation crumbled off and there was a hole underneath with water in it. What would cause that?
Most likely water up against the foundation wall exterior.
You have a major problem
First make sure that any water - rain or otherwise - is not allowed to build up or seep back towards your home
Rain gutters need to extend out 5 feet or more away from the home. Flower beds need to be graded away from the foundation.
You may have legal recourse with the seller and or appraiser depending on the laws in your state
I am so sorry to hear about your problem - your troubles are just starting Good Luck
Mar 08, 2010 | Plumbing
We built an outdoor room and the dryer vent is now "indoors".
you'll have to go to lowes or home depot and buy the rigid vent pipe not the flex type. Figure up the elbows and straight pcs. Usually vent pipe is 4,6,8 So make sure you get the correct size. Now as far as going through an existing interior since the vent pipe will be larger than the wall studs you want be able to go through the walls unless you have 6in. stud walls and the vent pipe for a dryer is usually 4in. I think. If you do have 6in interior walls you can run through them but make sure it's interior walls instead of outside wall interior walls usually dont have insulation. If you can't go through the walls your next option is simply through the each floor and out the roof or out the wall. Build a square chaise around the vent with 2x4 lumber, drywall and finish.Be careful if you go through the walls you may have to reroute wiring and water pipes.
Sep 07, 2009 | Samsung DV337 Electric Dryer
Water build up nin dryer vent
Hi, W/D here.
It would be best in your circumstance to slope your vent like one might slope a drain. 35 feet is waaaaay too long, 20 feet is max, and you can deduct 6 feet for every bend. If you can reconfigure your vent to a sloped drain, this will help.
The coolness of the basement is a contributing factor, but normally, it doesn't figure into the issue.
If you cannot shorten your run, or slope your line, you might do well with a trap that would have a mini sump pump in it. These are available from A/C companies, and are automatic in their operation. I have had one in one of my units, and the cost wasn't unreasonable. You can probably find one on-line (EBay?)
Venting into the basement may resolve your water issue, but you still have to deal with the lint that "escapes" the lint trap. Most of it will likely wind up in the air conditioner, and all over whatever you have in your basement.
A mini sump sounds like your best option, even if you have to set up a schedule to clean it out occasionally.
Best regards, --W/D--
Aug 12, 2009 | Maytag Dryers
York Gas Furnace Model # P2MPD14N08001A - Combustion Air
where are you getting combustion air from now in the midwest 1sq" per 1000 btu York.com with the model number
Jun 16, 2009 | Heating & Cooling
Maytag stackable washer/dryer gives off a lot of moisture
you answered your own question, its not producing to much miosture, its not releasing hte moisture with in the clothihng, Id be willing to bet that you have a MAJOR clog within the venting!!!!!!
Mar 28, 2009 | Maytag Dryers
Water Coming in basement
check out side where the water is going into the basement, aside from the gutter down spout, you going to need pack some earth so that the water will running towards the yard. If it is where the gutter down spout is, then you need to get a gutter extension direct the water some where else.
DO not paint the basement wall, you will have mod. however, you can waterproof the wall when the weather gets to be above 55 degree.
Jan 09, 2009 | Rival 38651-C 6-Quart
Dryer Doesn't Dry Well: Take two full drying cycles.
if at all possible disconnect vent from behind machine and run a cycle with wet clothes( lint and moisture will be fllying around whih is why i said if possible) if it works then you know there a restriction in vent line leaving the home. Most problems relate to poor/ innadequate venting!!!!!!
Mar 02, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
