Question about GE Spacemaker JVM1640SJ Microwave Oven
No power at all
My spacemaker just stopped. No lights panel underhood light etc
    President:
  • 1,952 Answers
Open and remove outside panel. Inside next to the plug in (power supply) there will be a glass fuse. Look inside the fuse and see if you can see a thin metal wire running across the entire glass tube. If it does not touch end-to-end, then it should be replaced.
If the fuse is good, then you may have faulty power supply or even bad circuit board
Posted on Jul 22, 2009
Ge spacemaker microwave jvm1640cj03 stopped heating. interior always clean. light, timer etc working.
If it stops heating and the other parts of the oven still work, the problem is with the magnetron circuit. If it makes a loud buzzing noise when you try to heat the food, then the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to have it fixed. Sorry.
Apr 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Won't turn off. Light on and fan running but not heating. Power off and power on and it works for a while. Now it is just off. No lights on control panel.Power off and on and then it works for a little...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 16, 2010 | GE Profile Spacemaker II PEM31 Microwave...
I have a GE Spacemaker JVM142K003 over the counter microwave and about a month ago the lights and exhaust fan stop working what can I do to fix this?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Clock works panel lights up but it won't heat
All of a sudden last nigh it just started acting weird the panel works and the clock etc works as well as all the cooking setting. but it doesn't light up inside and when I close the door to my GE Profile Eterna Space maker it starts huiming like its cooking something
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My 3 1/2 year old ge spacemaker over the oven microwave with vent fan has stopped rotating inside.
Did the cooktop lights recently fail?
If so, then the problem is probably on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Same problem - panel out - no light
If the fuse is good, then you may have faulty power supply or even bad circuit board.
Jul 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PRofile Spacemaker 2.0 - power off
I would suspect the magnetron thermostat or the oven thermostat. In some models, they are called TCOs or thermal cutouts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 15, 2008 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker JVM1640SJ Microwave Oven Logo
97 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
