HDTV backlight turn off after 10-15 minutes, with some t-shooting
My Polaroid TV is having power supply problem. After 10 minutes of so, backlight turns off. I am electrical engineer, so I looked at circuit board.. Component NTC1 (Thermistor) Is getting to 90C after short time.. After blacklight cut off, part cools significantly.. Was wondering if this is abnormal operation for this In Rush Protection NTC Thermistor, and if so how can I find specs, as this is unmarked part..
Power Supply Circuit Board is: Proview IPOS 250 A40
TV is Polaroid TLX-04240B
When blacklight goes out, rest of TV (sound, and LCD rendering is working normal) Checked LCD with SPOTLIGHT.....
  • 2 more comments
  • jwangelinjr Sep 10, 2009
    NTC component is in the AC feed to the TV for In-Rush Current Suppression.. It looks like 5-10ohms at powerup, and as it conducts and gets hot, the resistance goes to near zero. The spec I read on the NTC is that its normal operating temp is 150-200F..
    As for the Burn switch, that has also worked for me.. My thoughts are that since my backlight was going out every 3 hours then deteriorated down to <5min, that there must be a protection device on the HV backlight supply that has been degrading over time.. I did measure initially that there was an interrupt being received at the mpc, and it was sending a poweroff signal to the inverter chip.. The Burn switch must ignore this interrupt.. I still see it being driven to the mpc, however now the turn off signal is not coming out of the mpc, to the inverter chip..
    For now, I may leave the set as is, but if time permits, I will look at the protection components, and do some part swapping to see if I can fix it to run in regular mode..
  • mrkh May 11, 2010
    Thanks for the updates jwangelinjr. Have you any idea what other protection components are in the circuit other than the NTC? Were you able to probe where the interrupt to the microcontroller was coming from? There are analog inputs on this microcontroller, so perhaps it measures the backlight current (this could explain the 40" and 46" DIP switches - different current limits), but I can't see any resistors small enough to be for current sensing. There are three resistors under the top of the righthand heatsink I can't see the values of, however. Cheers, Ken
  • mrkh May 11, 2010
    I've opened up my TLX-04240B to flip the BURN switch, and just for the info of anyone else here, the microcontroller on the power supply board is a NEC uPD78F9222 http://www.am.necel.com/micro/product/su... and the PWM controller driving the inverter is a ST Microelectronics SG3525 http://www.st.com/stonline/products/lite... As far as I understand from jwangelinjr's comment, it's this microcontroller that sends the shutdown signal to the PWM controller based on an interrupt it receives.
  • mrkh May 11, 2010
    Jwangelinjr -
    Did you have any success finding out about the NTC thermistor? Did you
    try cooling it with a fan or similar to see if that delayed or
    prevented the backlight turning off?
    cdmc -
    Is your TV still working well after flipping the BURN switch? I'm not
    sure if you read in the other threads that there is an advanced/service
    menu for this tv... http://www.avsforum.com/avs-vb/showthrea...
    On this menu, I noticed a "Burn" option - I wonder is this somehow connected with the switch on the control board?
    As for why flipping the BURN switch seems to fix this problem, it's
    hard to know. I'd speculate this switch is related to burn-in testing
    (note that this is not related to pattern burn-in on a CRT or LCD due
    to displaying the same picture for a long time) at the factory where
    they run all tvs for a period of time to weed out any that are going to
    fail immediately. Speculating further, I'd guess that that the burn
    switch runs the tv in a more stressful mode (e.g. higher backlight
    intensity and similar things) to help weed out problems. Connecting the
    dots with pure speculation, I'd say that the tv normally has some
    safety shutoffs (perhaps upon hitting a temperature limit or a current
    limit), but that these are disabled in the burn mode.
I have read everything I can find on the net about this problem for Polaroid TLX 04240b TVs (most, like mine, bought from Wal-Mart on Black Friday after Thanksgiving). I thought I was on a hot lead when I changed a 220uF 450v capacitor, but I still had the same problem. I saw a short post from somewhere else on this Fixya web site (sometimes I can find it again and sometimes I have trouble locating it) that said someone flipped a tiny switch on their circuit board and the problem was gone. I did the same thing and my set has been working fine. They had said their set was on for over 8 hours two days in a row when they posted. The other night my daughter left our set on over night for 20 hours and the picture still was working great. If you look through the top of the set when the picture is on you can see some white light at several locations, when the screen goes blank the white lights go out and a red LED light can be seen. If you take off the plastic cover on the back (3 screws) and then take off the metal cover (3 screws) this red LED light is on the upper circuit board in the lower left corner. Just a little to the right of the LED light is a small switch block that has 4 tiny white switches. I turned my set off and took the bottom switch (#4 and had the letters BURN by it) to the right "ON" position, turned the set back on and, so far so good. PLEASE NOTE!!! I know almost nothing about how transistor circuits work. I have no idea what the switches do or what long term effect this might have on the set. The set was only good as a paper weight before so even if this only fixes the set for a short time it was at least worth a try for me. Does anyone know what those switches are supposed to be for????
Posted on Aug 13, 2009
Testimonial: "Great information, thanks! "
  • phantomlord_
    phantomlord_ Apr 15, 2013
    I Tried this fix, it works like a charm. thank you so very much.
  • 585 Answers
Also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1 each
look at the individual flouresent bulbs if one is dark or unlit before they all go off the panel is bad
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 01, 2009
Polaroid 42 LCD TV - Backlights turns off after powering on
The back light LED array is faulty. May be it would be difficult to get the LED Array Because its comes withe the LED panel. Try to consult Polaroid service center.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 08, 2016 | Polaroid Televison & Video
My 40" polaroid tv won't turn on, it has power because the red light is on, but won't turn on. Is there a reset?
if you have volume (audio) then the backlight is not working if you have audio look real close at screen you can see movement if you can power supply is bad or at least the 24 volt section is not working
Oct 10, 2010 | Polaroid FLM-4034B 40 in. LCD HDTV
The tv will turn onto the polaroid title and it turns off
There are one or two typical causes of the problems. The 24vdc power supply is bad due to bad DC filter caps, or the backlight inverterter board has short circuits. Those are the two areas to start checking first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 13, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Have a TDA-03211C Polaroid TV. It doesn't turn on, How do I know that the tv has the power supply broken?
This is what you need to do:
1) Look to see if the power supply module has any caps with leaking/bulging tops.
2) If you do have any indicator lights on the front panel, then it means the Standby 5vdc power supply section is working for the main logic to operate. Look at the termnials of the power supply that is labeled with STBY5V or something like that. This is a MUST HAVE voltage to get th TV started.
3) When the power button is activated, it will send out turn on signal #1 to the power supply module to turn on the main 5vdc (for the rest of the logic ciruites), 12~16vdc (for sound power amplifiers), and the 24vdc (for the backlight inverter board). Another turn on signal #2 is sent to the Backlight on/off control pin on the inverter board. Signal #3 is for turning on the T-CON board LCD panel.
It uses all these turn on signal so when the TV is in standby/sleep mode it will not consume all these power to save electricity and pass Energy Star compliance.
So now you have some basic ideas how LCD TV works and what is needed to turn on the TV.
Check out those voltages before it is on and after it is on
http://www.badcaps.net.
Jun 14, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Powers on TV works for 30 - 45 minutes then the screen turns black audio still runs.
take a strong light and place it next to the screen when the problem returns. Do you see a faint image on the screen? If so, then your backlight has failed. Since it happens after that long a time, it is probably a problem with the inverter board and or power supply for the backlight. Bad lamps usually go off after a few seconds. The problem will appear sooner as time goes on.
May 05, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
MY tv turns on but has no picture what is wrong?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Please post back what you find.
Dec 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid flatscreen picture does not stay. When the tv is turned on, the picture will last a few seconds to a few minutes.
Dec 13, 2009 | Polaroid TDX-02610B LCD TV
Screen image turns red after 15 minutes
Ur backlight video board it,dying.Micro processor have shorted,must change the backlight board.
Nov 24, 2009 | Polaroid FLM-3232 Television
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Televison & Video Logo
1,857 people viewed this question
Top Televison & Video Experts
