Color wheel on DLP TV about to die
It's been making noise for a long time, now it stops and makes weird colors occassionally. Sometimes the TV shuts off and the pic goes away completely.
  • 8,617 Answers
Eventually the set will refuse to power up, better to change the color wheel, as it could shatter and cause further damage in the light tunnel
Posted on Jul 22, 2009
Have a dlp samsung HLT6176S no picture already replaced the bulb still no picture what gives
Remove the lamp and look at the color wheel that faces it.
If wheel is shattered or missing pieces set will know it is not moving or moving too slow and shut set and lamp off.
Not all color wheels when fail make a sound
May 06, 2012 | Samsung DLP HL-P5663W 56" TV
My first gen samsung dlp tv makes noise from back and will not turn.when it happened it was going in and out of color
Tv have a colors wheel.Colors fade in and out or flashes black and white within the picture.The tv making humming or loud motor noises the colors wheel is dying and not spinning correctly in it motor anymore.The tv must have it colors wheel replace,will solved this problems.
Jan 01, 2011 | Samsung DLP HL-P5663W 56" TV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Tv is making a loud buzzing noise and the picture is all funny ie colurs are out and pixelated
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.
Apr 05, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Lost color, loud buzzing sound HLP4663W
This can be the colour wheel assembly, or the servo drive board, or a fault on the circuit board that does the sync processing for the colour wheel.
You will have to have the set properly serviced.
Jerry G.
Mar 29, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung dlp tv hls 5688w problem
Possibly a bad fan. operate the set for at least an hour to warm it up then shut it off does the noise continue for a moment? If so its probaly the fan for the lamp that is making the noise.
Mar 20, 2008 | Televison & Video
HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Apr 01, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
