Question about Acer LXA3706003 Notebook
Acer Aspire 5520 screen and NVIDIA driver problems
13 months ago my wife and I purchased an Acer Aspire 5520 Laptop running Windows Vista. The laptop ran fairly well for the first year until one morning when we turned it on and saw nothing on the screen but a light grey background with horizontal and vertical lines running through it. The CPU fan was running and the hard drive and wireless connection lights were active as normal.
We tried a series of reboots but the situation remained the same.
Considering that the laptop screen itself may have died, I hooked up a spare flat screen monitor through the side monitor port and booted up again. The Acer start-up screen appeared on that monitor and then we were given the usual choice of boot normally, repair system problems, safe mode etc.
I tried the normal start up and was greeted with the blue screen of death (which only lasted a few seconds) mentioning something about a display driver timeout or something along those lines.
I tried a series of reboots using F8 as the system repair option failed and managed safe mode; safe mode with networking etc (broadband internet connection was successful) and even tried the old chkdsk/f repair check option.
We continued to try everything; I even download the newest NVIDI drivers and once or twice the system appeared to work normally and then we were back to square one. Tried for a normal reboot over the following few days (most of the time it would shut down after a few seconds without reason) and then one evening it rebooted normally.
I used the EAcer recovery (full recovery) from my full system backup from four months ago in the hope that any software changes would be corrected.
This was successful and the system worked ok for 2.5 hours before freezing up and on reboot – the grey screen was back.
I noticed on many occasions that the CPU fan was not working at all; or only intermittently; and on a few occasions the screen was completely covered with small letter a’s (a).
I contacted Acer support and they sent me an SMS text message with instructions to restore it to its factory default – which basically formatted the disk. Now the system won’t work at all in any mode and we have sent it off to be repaired.
I have noted a number of web forums discussing the various issues with the Acer Aspire 5520 and a lot of the discussions sound familiar; but it isn’t clear as to whether this may be a software or hardware issue.
Has anyone else experienced these issues??
    President:
  • 828 Answers
Its a hardware issue, and why its your motherboard on laptop have a problem, not physically but i think your try to re-update your BIOS to clear out all the malfunction chips inside your laptop. This problem was actually i encountered before but no one also understand why is always came back the problem on it. Go to the website on the ACER www.acer.com to download the latest BIOS updates on it.
You should install it one by one or step by step like for example 1.0 then 2.0, like that. And don't be so hurry the BIOS is a very delicate setup rather than Windows System.
Basically restore the BIOS setting on default after that installation.
This installation might help to you with that problem and dont forget to unplug all unnecessary input devices so that it will not hang up again. Afterwards run Disc Recovery Disk to setup Windows System, good luck! Bboy
Posted on Jul 22, 2009
Acer is aware that the video chip on these 5520 models is bad, yet they never did or will do anything to correct this problem. I will never ever purchase another Acer product of any kind and I suggest to everybody to stay away from this company .... they don't stand behind their products.
Posted on Mar 25, 2013
@alejandro732
It is not an Acer specific problem. HP with AMDx2 and NVidia does the same. I tried some. We can find other brands with the same config, same problem. The CPU-GPU heat producing and the machine cooling design is very poor. I would like to think it was the years 2007-2008-2009 problem, but better think twice buying AMD with Nvidia.
Posted on Aug 10, 2012
The problem with this model 5520 is the video chip, it fails after some months of use, it has to be replaced, the origin of the problem is a desing one. The problem will persist to reappear after a few months of replacing the chip, so, the solution would be to buy a new one and be cautious about buying acer laptops.
Posted on Jul 07, 2012
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
MY ACER ASPIRE 5520-5912 LAPTOP POWERS UP,BUT WON'T OPEN TO WINDOWS VISTA.HELP ME ,PLEASE.
go into safe mode and run spybot search and destroy...you might want to run AVG also.
Dec 29, 2009 | Acer Aspire 5520-5156 Laptop
Lost most drivers including network drivers on my laptop
some laptop design for vista if you donwgrade. it cames a lot of problem especially the driver.. sometimes not working the,, sound, ethernet or vga.. not available the driver from the internet. even you contact the technical support to ask them regarding the drivers. but mybe they can give you the driver..
try and try untill you succsess
Jun 02, 2009 | Acer Aspire 5520-5156 Laptop
I've installed w7 for my acer aspire 4930 but still cant find any drivers for nvidia
Hi there. Currently, Acer do not have any graphic card driver support for Windows 7, the reason is that they have to wait for NVidia to program a driver for Windows 7, then Acer programmers will modify the driver for their products. NVidia are currently working on drivers for Windows 7, but they will be for actual NVidia cards, i.e AGP and PCI/E. Drivers for laptop intergrated graphics, normally run anywhere between 6 - 24 months behind the general manufacturer's release.
If you follow this link to Microsoft, it does explain the risks of running Windows 7 beta, including, printers, video cards and other hardware that may not work.
http://www.microsoft.com/windows/windows-7/beta-faq.aspx
Apr 15, 2009 | Acer Aspire 4930-6862 Laptop
Nvidia laptop sound drivers
Try downloading the appropriate driver from the Acer website. Note Acer shows your model of laptop having Nvidia Chipsets for Video and Motherboard, install the following drivers listed
nVidia Chipset Driver v13.11 Aspire 4520 Windows Vista RealTek Audio Driver v6.0.1.5413 Aspire 4520 Windows Vista
Here is a link to the main page - Click Here
Mar 19, 2009 | Acer Computers & Internet
Acer 5520-5142 ?????
Try to re-install Microsoft Office... and then see...
Aug 24, 2008 | Acer Aspire 5500 5570-2609 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer LXA3706003 Notebook Logo
2,061 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
