Question about Sony Ericsson K850i Mobile Phone
Cellphone was dropped accidentaly in a tub full of water
  • 178 Answers
Yikes, try the old standby- remove the battery, sim card, memory card, and get out a hair dryer. Set it on low and carefully blow warm air into every nook and cranny of the phone for about 5 mins. Then blowit on everything else as well- attery, sim. memory card. Placed everything on a towel for 48 hours or so, pray a lot, and 2 days later put everything back together. Change up the battery to the max, before you turn it on for the first time, and pray one more time. If you're lucky everything should have dried out nicely, and the phone will work. Do not under any circumstances try to turn on the phone unless it is thoroughly dried out, because water and electricity just don't mix.
Posted on Jul 25, 2009
My lg kp320 went off and can't turn it on again
is your battery old already? have you dropped your cellphone in anyway? is the battery full charged? first step: 1. replace the battery with a new one. 2.if you dropped you cellphone,look for a nearest cellphone repair shop and let it repair by the cellphone technician. 3.charge the battery full.
Jun 16, 2011 | Cell Phones
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Lg dare touchscreen not working all of a sudden.
possible cause, you may be accidentaly drop it, or seat on it...
first if it has it manual keypad, then use it and try to set on factory setting default.
Default security code..12345 or 1234
see if it works but beware , all your personal profile might erase, but before doing it try to remove the sim card and memory card.
if it still not work then bring it to cellphone technician, there is a possibility that the flex (tape wire type) or the black crystal(small IC part)migh be damaged
Oct 29, 2009 | LG Dare VX9700 Cell Phone
Few water drops in the TV - 1997 Magnavox
check the vertical section,look for burn resistor or try replacing the vertical ic.
Aug 06, 2009 | Quasar SP-3235 32" TV
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Sears CAlypso
dont see why not, first t hing to do is find out where its leaking from, the fromt panel will need to come off to watch for leak in order to remove that , pop off the medalion on fron lip of the main top assy. ther should be a screw behind the emblem remove the screrw and the top will slide foward and then tio back. a few screws across the top of front panel will drop that panel down adn from ther you ll gain acces to watch unit work adn see where water is coming from
Apr 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Enhancement program
there is something wrong with ur headset connector which at the bottom of ur phone.may be inside phone where it connects on PCB, there have some problem with its connection. better u take it to technician for better solution.it need to be repaired.
Feb 23, 2008 | Nokia N72 Cellular Phone
Sony Ericsson K850i  Mobile Phone Logo
105 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
