Question about HP OfficeJet 7310 All-In-One InkJet Printer
7310xi all in one problem copying
Try to copy from scanner and it stays stuck on warming up and then screen goes blank and paper feeds 1/2 way then nothing
  • 241 Answers
Sorry, but it's a goner, cheaper to buy a new one then to have it repaired. It's probably manufactured discontinued now anyway.
Posted on Jul 22, 2009
How to fix a paper Jam?
quality of paper and the paper thickness setting may have something to do with it.
Jun 28, 2015 | Brother MFC-7440n Laser Multifunction...
I cannot copy and print a document on 8"X14" plain paper. No problem with 8"X11 1/2" plain paper
Scanner: dot2.gif optical resolution: 2400 x 4800 dpi /19,200 x 19,200 dpi interpolated dot2.gif 48 bit color depth
maximum document size: 8 1/2 in x 11/11/16 in dot2.gif Copier: dot2.gif copy speed for text documents: up to 30 copies per minute in black; up to 20 copies per minute color dot2.gif reduction/enlargement: 25/400 percent dot2.gif Fax: dot2.gif color or black and white faxing dot2.gif stores up to 40 numbers in speed dial dot2.gif built in memory for up to 100 incoming fax pages General Features: dot2.gif automatic document feeder holds up to 30 originals for copying, scanning, or faxing multiple documents dot2.gif Ethernet port for connecting multiple users in a computer network dot2.gif 2 picoliter sized ink droplets for fine detail 4 individually replaceable ink tanks dot2.gif ChromaLife 100 inks for long lasting photos dot2.gif Full photolithography Inkjet Nozzle Engineering /FINE 1,600 nozzle print head dot2.gif paper sizes: letter /8 1/2 in x 11 in, legal, credit card /2/ 1/8 in x 3 3/8 in, 4 x 6, 5 x 7 in, envelope, photo stickers dot2.gif high speed USB interface dot2.gif 18 15/16 in W x 9/ 7/16 in H x 18/ 1/4 inD dot2.gif weight: 22.3 lbs. dot2.gif Part Number: 2186B002
you have to select the paper size from the computer while giving printout from computer and apply the changes you make.and while copying the page from the scanner you have to change the printersettings by clicking the menu button in the printer.
Oct 04, 2008 | Office Equipment & Supplies
When I try to make a copy the machine make a screeching noise and a blank copy comes out.
Leave the lid up when you make the copy and see if the light bar moves from left to right when copying. Check the scanner lock knob under the left hand side where the papers come out. Make sure it is not locked. Sometimes the scanners get stuck a lot and can cause blank copies. If it is stuck then you just have to remove the glass and then clean and lubricate the steel bar at the back that the whole unit rides back and forth on. Once that is doene it should work fine. Make sure to manually run the scanner bar out and back a few times so that you can get the whole rail lubricated. Do all this with the power turned off.
Good Luck and Thank You for using Fixya.
If I helped, please let me know via a testimonial today!
Oct 08, 2010 | Sharp AL 1631 Copier
Scanner or copy not working on hp PSC 750
Copier feeds blank paper to copy but does not copy
Sep 04, 2010 | HP PSC 750 All-In-One InkJet Printer
When trying to fax or copy our invoices (paper is not that thick) gets stuck in the machine and bunches up. Very frustrating because it ruins the invoice. How to get this problem from occuring.
Most of the invoice paper is to thin or it is chemical treeted that is not suiteble for paper feeding.Use a copier with a flat bed scanner to copie invoice papers.
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Blank copies
see the cartridge do is good installed.
Remove the cartridge and putt it again.
If the problem do not go away please try with other cartridge.
Or if the printer is ink-jet printer and you have not used it for some time than the ink can be stuck
Jul 16, 2009 | Office Equipment & Supplies
I have HP all in one. The feed for fax stopped working. how do I fix it.?
try copying blank pages. If it feeds the paper, then try faxing again. If it does not feed the paper, then open the feeder and clean the rollers and the separator pad. You can use a coffee filter moisten with distilled or bottled water to clean them.
Try copying blank pages again to check if it feeds the paper.
Feb 18, 2009 | HP Office Equipment & Supplies
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
HP OfficeJet 7310 All-In-One InkJet Printer Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
