Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Green diagonal lines across picture on Mitsubishi WD-52725 TV
Replaced bulb within past year but TV doesn't seem to recognize that fact as red light stays on. Is this a bulb problem?
  • Mitsubishi Master
  • 8,617 Answers
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Posted on Jul 22, 2009
WD-52725 Picture Quality Problem
sounds like a possible issue with the Optical light engine itself.
Nov 28, 2012 | Mitsubishi WD-52725 52". Rear Projection...
Model: 52725 we hooked an xbox to this thing and it wont give us a clean picture, rather black and white fuzzies and has green lines shooting across the screen, sometimes purple going across the screen...
There are small surface mounted capacitors on the dm Board and the fmt board that have gone bad. They need to be replaced. Most tv techs will charge about $400 to do this.
Mar 16, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Have a WD-52725 Mitsubishi TV. Notices lines
Ur tv have convergence problems before,that why tv getting colors lines somtimes alot,sometimes not.The 2 STK convergence ICS was defective.Now the 2 STK convergence ICS are now totally dead.The shop will cost u $300-350 for parts and labors for the 2 STK convergence ICS,and it supporting resistors.
May 12, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
FLASHING RED LIGHT
Same problem as my Sony. Unplugging for 36 hours solved my problem
Dec 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Wd-52725
mine did that and the motherboard had to be replaced. no problems since then
Mar 26, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
479 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
