Question about Minolta EP1030/1030F CS/PRO Copier
  • Anonymous Mar 26, 2014
    where is the imaging removal tool
    Problem Solver:
  • 4 Answers
1. Remove 2 silver screws on plate that aligns your original -on left side of glass. (note: if ADF on machine, there will be two small springs under this plate, be careful to keep springs when you remove the plate) 2. Carefully remove glass by lifting slightly and sliding to the front. 3. Grasp carriage with lamp and pull to the right.
4. The lamp is held by tension between two silver lamp terminals. You can press (hard) on the rear terminal toward the back of the machine and the lamp will release and drop onto the reflector. Or, if this is difficult, remove the screw(s) on the black plastic housing that holds the silver lamp terminals. Once loose,
slide the lamp to the rear until you can lift the front up and out.
5. To replace the lamp, USE CAUTION NOT TO TOUCH THE NEW LAMP WITH YOUR BARE HANDS! The oils from your hand can cause problems later. Use rubber gloves or wrap a paper towel around the lamp when handling. Slide the lamp all the way into the rear hole until you can get the front of the lamp into it's hole. Then, maneuver the lamp onto the front terminal
while pressing the rear terminal until it's wide enough to accept the lamp. (or, if you removed the black housing, catch the lamp socket with the terminal then pull the housing toward you until it seats into position where you can reinstall the screws). 6. Replace the glass being careful to get the right side under the two metal spring clips. 7. Reinstall the original stop plate located left of the glass with the two silver screws (and the springs if ADF is attached). 8. Plug it back in, turn it on and away you go.
Posted on Feb 26, 2008
Where can I download service manual for Minolta pro ep 2030. Free if possible
i can download it for you send me an email to forward it to you
Jan 31, 2011 | Minolta EP1083 CS/PRO Copier
How do I remove the fan switch to replace it on the dash under the radio?
Have your radio code before you pull it out with the right radio tool. This pull would involve removing this parts.
  1. Glove compartment
  2. Driver side panel
  3. Center top dash board
  4. Defrost switch carrier
  5. Radio unit
  6. Center lower half of dash
So I'd suggest go to your local public library and look for your car manual. It would be either Chiltons or Clymers manual, it's not as precise a Bentley VW Official factory repair manual. Yes it really involves taking all those parts out just to get to the rotary switch.
Apr 20, 2010 | 2000 Volkswagen Beetle
I just bought a used EP 2030 CSPRO for my personal Classroom use but when I try to copy it only gives out all black copies. Any idea? Thanks Byron Cowan
Try to copy with the glass cover open, once the scanner moves you should see that the halogen lamp is lighted. If not, either the lamp or the thermal fuse is busted.
Oct 12, 2009 | Minolta Office Equipment & Supplies
Ep 2030 error code c06
Exposue lamp, does the lamp come on under the glass at all. Open close the front door, if that code comes back your exposure lamp is gone. Thats the bright ligh that comes on while making copies.
Jul 16, 2009 | Minolta EP1030/1030F CS/PRO Copier
Minolta copier EP 2030
This unit has a history of the High Voltage unit going bad. NOT good news, and NOT a cheap fix.
Jun 24, 2009 | Minolta EP1083 CS/PRO Copier
Whow to claer code
i repear sharp canon copier please send me details
May 30, 2009 | Sharp AL 1631 Copier
Minolta copier EP 2030 error code C 04
No, in stand-by the exposure lamp should not switch on. What comes on in regular intervals is the heating lamp inside the fusing roler which can be seen from the exit side of the copies. The exposure lamp is under the glass and only comes on and print button is pressed and copy process begins.
Nov 04, 2008 | Office Equipment & Supplies
Meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Nov 15, 2007 | Minolta EP1030/1030F CS/PRO Copier
104 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
