Question about Microwave Ovens
The water and ice filter case has cracked off when I tried to remove it and now part of it is still in the base of the refrig. How can I remove the filter case?
  • lhoff0651 Jul 22, 2009
    It is a kitchen aid refrigerator kssc42qms01 model. How do I access the screws you mentioned?
    kitchen aid refrigerator kssc42qms01: How do I access the screws that hold the water and ice filter housing at the base of the refrig in order to remove the cracked and broken off housing?
  • 3,037 Answers
You should be able to remove the water filter housing from the front of the refrigerator, but you will need to shut off the water supply
before starting work from the front. Once you have the water off, with the unit still plugged into power, go to the dispenser and activate the water dispenser. This will remove the pressure off the lines for a step later. After that, disconnect the power to the refrigerator.
Once you have that done, just remove the front grill. It is attached by a clip on each side. Just pull with enough force to yank it loose. Sometimes it seems like you are going to break that plastic, so just be careful on that.
With the toe kick plate removed, you just remove the 2 screws securing the filter to the front frame of the unit. Reaching back along the left hand side of the house, there will be 2 water lines coming into it. There will be a small plastic ring on each connection. (If I remember right, one is red and the other is gray.) You will need to press these in, towards the filter housing to release the water lines and then pull the lines loose. There isn't much room to work and it isn't the easiest and if you don't want to break anything else and avoid the hassle, then you may just want to call a repairman out to fix it.
Otherwise, with that all done, the housing will slide right out. Let me know how this works out for you.
Benjamin
Posted on Jul 22, 2009
  • 10,865 Answers
Hello. As you will see, for some reason your problem got listed as a microwave and not a fridge. That said, since you did not name the brand and model I will give you as good an answer as I can in the generic category. The filter case is attached to the frame of the fridge with two screws. If you get right down there after you remove the grill you will see them. they may be a bit of a challenge in close quarters but with the right tools you can remove them.
How do I clean the filters
remove cover after remove filters you should clean the filters by water based detergent
Oct 24, 2014 | GE Spacemaker JVM1540 Microwave Oven
My lg fridge is giving me an error code of FF what is this mean
Your LG refrig is in Demo Mode.
1.- disconnect power supply and reconnect
If the error continue
1.- Open the door of refrig.
2.- Press button "Refrigerat" while press "Ice P" button 15 seconds
If the error continue try again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | LG Microwave Ovens
We stopped getting water from our Kenmore freezer door dispenser. I have verified the solenoid valve is working. The line from the solenoid outlet to the dispenser appears to be plugged (can't blow...
Many times the lines get frozen as they run through the back of the refrigerator section. Sometimes simply turning the temp up in that section will open the lines. Additonally, you might have to remove everything from the unit and totally defrost it to clear it. IF it's Ice.
Do you use a filter for the water comming into the unit? IF not you could have a blockage. If that is the case you will have to find where the block is and remove the block.
Jul 23, 2011 | Microwave Ovens
I installed a new fridge filter and now my ice maker will not make ice.
Check the direction of the water flow for the filter, did you put it on backwards? Did you open the pep-**** to allow water to flow to the unit again? Did the ice-maker line freeze up when you were changing the filter. These are all things that are common mistakes when changing the filter. Check this things out and get back to me with an update...
Jun 14, 2011 | Microwave Ovens
KENMORE COLDSPOT MODEL10652212104 THE FAN IN THE FREEZER DOESNT SEEM TO RUN, DOESNT FREEZE ICE EITHER BUT IT DOES HAVE WATER IN THE ICE TRAY. THE REFRIG PART DOEN GET COLD EITHER WE REPLACED THE VAVLE...
Hi, if the fan, evaporator fan is not running, it has failed on you. If you are up to doing this kind of work, you can replace it your self. It is a 120 volt evaporator fan motor, and if you can get it out, take it with you along with the name of the unit, model & serial # to an appliance parts house to get one. If they don't have the exact one, they have universal ones that will fit. This will solve your problem.
Shastalaker7
A/C, & Refrigeration Contractor
May 16, 2011 | Microwave Ovens
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
We got a new kenmore frige and when we hooked up the ice maker/water dispen. water came running out from under.
check your connection where you hooked water up to the frig. Also on some models there is a water filter on the front toe-plate. These filters will leak if they have a crack in them, so try replacing the filter first. If the filter and the connection are not the problem, you might have to replace the filter housing. Hope this helps, Clint
Mar 21, 2011 | Microwave Ovens
Have Kenmore sid-by-side refrigerator: 7909621940B - Just changed water filter. Now, no water or ice dispenses. Ice maker is making ice - filled the bin over a few days. But, when I push to dispense...
We also have a kenmore side by side refrig and had the same problem,,,
FIRST, CHECK THE CONNECTION BETWEEN NEW FILTER AND ATTACHMENT POINT,,
IF THE RUBBER GASKET CAME LOSE DURING THE CHANGE, IT MAY BLOCK THE PATHWAY FOR WATER TO FLOW
NEXT, CHECK THE WATER/ICECUBES/CRUSH LEVER SWITCH TO MAKE SURE IT IS NOT PART WAY BETWEEN ONE OF THE SETTINGS,
NEXT,CHECK TO SEE IF YOUR UNIT HAS A RESET BUTTON,
THE RESET BUTTON IS USUALLY IMMEDIATELY INSIDE THE OPENING WHERE THE WATER/ICE DISPENSES AND UP, YOU WOULD NEED TO PLACE YOUR FINGER RIGHT DIRECTLY UP BEHIND THE FRONT PLASTIC COVER, AND IT'S GOING TO BE A VERY SMALL BUTTON, I AM NOT SURE WHICH SIDE ON YOUR UNIT R OR L, BUT DIRECTLY UP IN THE CORNER,,
I HOPE ONE OF THESE HELPS !! angi
Feb 05, 2011 | Microwave Ovens
My ge profile spacemaker oven is leaking water(?) i removed the metal filter and the liquid appears to be coming from inside. there is a metal "plate" about 1 inch above the filter and the liquid is coming...
unless something strange happened (like a spill) then the only component that has fluid in it is a large capacitor that is used to drive the magnetron ... if its case is ruptured then it will leak a few teaspoons of electrolyte .. thats a clear water or oil based liquid .. the failure of the aluminum case will cause a pop one time ... then its likelly the oven will quit working .. its also possible, if you have an outside vent for your microwave, that water is blowing into that vent down into the microwave .. check the exhaust to make sure its outside louvers are not damaged ..if it goes to the roof then make sure the rain cap is in place ..
Jul 02, 2010 | GE Profile Spacemaker 1.8 Cu. Ft....
According to the GE website I might have a clogged filter which is preventing my icemaker from making ice. they suggest I activate the filter bypass to test the water pressure. I can't find any filter or...
Hmmmm ... do I understand you have a ice maker in your microwave?
I suggest you pull your device away from the wall and look for a external filter or more instructions on the bacck of your ?. There may be a filter inside your (what ever your ice maker is in) .... Can you locate the end of the supply line? Is there a valve on it? If yes. turn the water off, remove the frig end, have someone hold it into a bucket, turn the water back on - let it run for a while. Turn it off. Get a report from your helper about pressure. Check the strainer that may be in the line where you hook the supply pipe to the frig. Make sure it is clear and clean. Try again.
Let me know how this works for you.
Sep 21, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
