Question about Kenmore 60721 Refrigerator
Fridge runs continuously, not cooling
I too have a Kenmore Elite fridge without a freezer, 2 1/2 years old, and was a great unit, when new. It now runs continuously. All components operate properly, ie, compressor, timer, capacitator, etc.. Sears tech. tells me there is no gas is in the system (at a cost to me of $101.00 to tell me this). Because it's an "internal" freon leak, nothing can be done to repair it, The warranty will not cover anything, even though it's a part of the sealed refrigerant system. I have been told all I can do is throw it out, basically, tough luck. Thanks, Sear's.
    Sergeant:
  • 111 Answers
I would trust the technician - not much else you can do. You can't repair those. Mostly an iron/steel evaporator and they rust after some time.
Posted on May 01, 2017
  • 150 Answers
SOURCE: Refrigerator Water Leak from opening under Freezer
easy fix my man. couple of possibilities: 1) the fresh food gets cold air from the freezer via the vents where the water has been coming out. the water has frozen up in the vents and is blocking the airflow. the reason the water was coming out in the first place is a slow drain. open up the evaporator cover inside the freezer. get all the ice out of there and clear the drain. a little bleach will kill the gunk that made the drain flow slowly.
2) you have a defrost issue and the coil is loaded up with frost causing no airflow to the fresh food section. check the defrost heater limit and timer. none of these repairs should be over 150. but thats in lawton ok. if you live in L.A. or NYC get the wty.
Posted on May 07, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
SOURCE: kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Posted on Feb 01, 2009
  • 93 Answers
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Posted on Sep 13, 2009
  • 1218 Answers
SOURCE: Refrigerator/freezer stopped cooling during a heat wave
Good day,
Turning the thermostat to a warmer setting should not have caused the machine to quit cooling. Actually, the engineers give you far less leeway than you might think.
The controls are more in a class of fine tuning, otherwise people would be getting themselves into trouble. The manufacturers simply design the warm and cold parameters in a fairly narrow range.
The best setting is normal. When away, the machine will run far less simply because of no door openings. Opening a door lets in large amounts of air every time it's done, which is where your cost to run it exists.
Two things. One, if the temp in the kitchen exceeded 90 degrees for any length of time, you are operating it beyond it's design range, however two, it sounds as if the thermostat hung up, causing your issue. You may want to have it replaced, but it would be useless to call anyone when it's performing normally.
There is no test on thermostats other than by observing their action when the machine is not operating properly.
Posted on Jul 08, 2010
Testimonial: "Thank for your advice. This answers a number of questions. However I don't understand the last sentence. Could you clarify? Thanks again!"
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
12 yr old kenmore top freezer. Freezer get real cold but does not freeze. Fridge part does not get very cold. I cleaned all the dust from coils, fan runs and all the seetings are good.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
My kenmore elite all fridge does not get really cold any more, only the fan seems to be running and maybe not the compressor, its only 2 years old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 10, 2011 | Kenmore Refrigerators
My kenmore elite top freezer refrigerator (model 106.72999201) is only cooling the freezer not the refrigerator. Compressor is on. Help,
Switch off the fridge and after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
The circulation fan must be checked to work as if frost forms it can be stuck up . So check if the defrost timer works and also if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
Jul 26, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
2 yeaor old kenmore fridge not working, motor runs
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | Kenmore Refrigerators
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the line...call a tech out and have it checked...it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite 75212 fridge doesnt cool off
Well there is a diffrence between no air flow and not cooling is the freezer working?? We can go from there
Sep 16, 2007 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 60721 Refrigerator Logo
108 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
