Question about CTL Nexus NX3200 Television
Nexus 42" TV turns on by itself
My 42" Nexus TV turns on by itself, model #NX4230P. It does not come on at regular times, so it is not a timer and it is not plugged into a surge protector. The wiring and outlets are brand new.
  • kirknpam Jul 22, 2009
    Correction, the model number is NX4203P.
This is easy and so many people forget about the in built oscilating swivel diode!
It is a static caused effect affecting the remotes receiver depending on what surface the television is placed on.
Cover the zone on the television that receives the remotes signals (just place something in the way of that and the remote but closer to the television) remove the batteries from the remote and hold the 1 button, place the batteries in again whilst still holding one and remove the obstacle blocking the signal.
The signal is reset and the static will not affect again.
Posted on Jul 22, 2009
Nexus 42 inch tv won't power on
This sounds like a problem with the power board. Look on you tube for troubleshooting video's for your model. It depends how confident you are in working inside a TV but you can pick up a second hand power board fairly cheap on ebay. Remember always to specify the model number when searching for things.
Sep 09, 2014 | Nexus Televison & Video
I have a nexus 42 inch tv and lost sound. Not sure if my one year old pressed something on the remote because netflix, and DVD work fine
Tries tv and those cable or satellite boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgrade it softwares and for the tv to do a resetting itself back to factory setting,now go into the tv menu go to Audio setting tries resetting all back to the factory setting.By doing these steps.These steps,will help and have a great chances for ur tv to have it audio back for tv stations channels broadcasting reception.
Jun 24, 2011 | Nexus EX-4200 42 in. EDTV-Ready Plasma TV
SONY HDTV-LCD MODEL - KDF-42WE655 turns itself off. Lamp light indicator flashes red. Should I attempt to reset ? It is approx. 4 years old
I'd wager that somewhere in the menu settings, there is a "Sleep Timer". Check the menu for the sleep timer, which turns off the TV after a set length of time. Also, check your remote, there might be a "Sleep" button that would do the same thing, press it multiple times until it reads "Sleep: Off" or something similar.
Dec 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Random switch off
  1. Replace power supply module.
Aug 23, 2009 | Televison & Video
The unit turns itself on and off
Have you checked the tv on/off setting in your main menu? I had the same problem when tv would turn itself on at midnight and switch off at 12.30. Had accidently turned on the timer. Hope this helps.
Jul 12, 2009 | LG 42LC2D 42 in. LCD HDTV
Goodmand 42'' TV turns itself off
Check to see it your TV has a timer and it was accidentally touched to activate. Good luck.
Jul 04, 2009 | Televison & Video
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
The TV turns itself off after 14 minutes
Sounds like maybe you have a sleep timer activated?  There should be an option to reset the tv back to factory reset, this might help you.
Dec 12, 2008 | Toshiba 42HL167 42 in. LCD Television
I have an LG 42" 42PX4DV Plasma, keeps resetting itself.
Do you use a regular antenna, or cable/satelits tuner?
I use only satelite tuner, and had the same problem on a differnt TV. I solved it by connecting a regular antenna (actually just a piece of cable) and go through the search and store routine once. Then the TV remembered that it was configured. Before that it thought it was "fresh out of the box" every time.
Nov 26, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
TV turns off by itself (not timer issue)
Probable bad green CRT. Also, look for coolant leak from
CRT onto PCB.......T
Oct 24, 2007 | Samsung HCM4216W 42" Rear Projection...
CTL Nexus NX3200 Television Logo
204 people viewed this question
Top CTL Televison & Video Experts
Electro Med Services...
Are you a CTL Televison and Video Expert? Answer questions, earn points and help others
