I have a printonadime ink supply. I just need to reset my counter or reset the lockout.
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
I had the problem of the full ink absorber. I already washed and cleaned all the parts related. Now, I need to reset the counter; how I can do it??
<Ink absorber counter resetting>
Reset the ink absorber counter (to 0%) when the ink absorber is replaced, or after the logic board is
replaced.
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting
mode.
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s)
according to the kind of ink absorber whose value should be reset to 0%.
(13/32)
Time(s) *1 Ink absorber
0 times Main ink absorber (0%)
1 time Platen ink absorber (0%)
2 times Both the main and platen ink absorbers (0%)
3 times or more Press the ON/OFF button to return to the ink amount resetting mode.
3) Press the ON/OFF button to specify the ink absorber whose value should be reset to 0%.
4) After the ink absorber counter is reset, the counter value is printed automatically.
("D=000.0 Ps=000.0" is printed at the top left of the paper.)
*1: According to the number of times the Stop/Reset button is pressed, the LED lights as follows:
- Odd number of times: Alarm LED lights
- Even number of times: ON/OFF LED lights
Nov 01, 2013 | Canon PIXMA MX310 All-In-One Printer
I need to reset my Canon Pixma MP160 manually.
Follow the steps below to do Reset on your printer.
  • Turn on the printer to reset then run MPTool software
  • Click Reset Black on Ink counter to reset ink level black cartridge or click Reset Color to reset ink level on the color cartridge.
If this does not work, try the steps below
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Dec 13, 2010 | Canon PIXMA MP160 All-In-One Printer
Waste ink absorber is full
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Canon PIXMA iP1600 Printer
I am using samsung ml-2245 when refill the toner it is acccept the toner
Perhaps you'll need to replace its lockout chip. Toner cartridges have a page counter and that needs to be reset after the cartridge has been refilled. Printing won't commence when the lockout chip has not be replaced with a compatible reset chip.
Nov 14, 2009 | Samsung ML-2240 Laser Printer
How to replace ink absorber for Canon PIXMA iP1200
Canon Pixma iP1200 Resetter
Oct 25, 2009 | Canon PIXMA iP1200 Photo Printer
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
Ink absorber
actually ink absorber is full means you printer inside got small pieces towel
to absorb ink. but Canon PIXMA printers display an error when a certain internal counter suggests that the ink absorber may be full. If you've done a lot of printing, the ink absorber may actually be full and you might need to have it cleaned or replaced to ensure the best printing quality. However, if you haven't printed that much or you have and you just need to print something right this minute, there is a way to reset the counter and stop the error from showing up again
please try go to this website :
http://ij-forum.blogspot.com/2008/09/how-to-reset-ink-level-of-fine.html
the you go left hand side download General Tools (EEPROM Resetter) Collection and install on you cpu.
after download remember to turn on printer before install it.then go to Reset ink counter by clicking Reset main on waste ink counter menu
try this if can't i think you need send to shop for technician to open it and clearning for you....
Aug 17, 2009 | Canon PIXMA iP1600 Printer
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
