SOURCE: Height adjustment on power head
Generally, there are screws that hold the beater bar onto the vac head. Loosen them, remove the glop that got in there and you should be okay. If you remove the screws, note the location of all parts...Digital cameras are great things. If you forced the adjustment, you may have broken or bent something.
SOURCE: Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
SOURCE: adjust height level on uneven floor
Yes, the front two "feet" of the refrigerator are used to for leveling purposes. Don't forget to level front to back, and left to right. Hope this helps.
SOURCE: 99 Grand Voyager, headlamps adjusted too low. Do I
Purchased a 4 mm socket and had the necessary adjustment with the adjustment screw right above the headlights. Clockwise will raise the lights while counterclockwise will lower the lights.
SOURCE: Craftsman snowblower auger won't disengage. Tried
check the belt there is a tensioner on mine the work to tighten the belt when you pull the handle there may be something in there that is not letting it release all the way
Make a note of the tracking force setting.
Make sure the turntable is level.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Stylus Pressure/Tracking setting to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
