Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Modulation settings if i change the modulation settings it improves my speed but not for long  autosense sees the weakest setting why?
    Scholar:
  • 193 Answers
No u dont need to change teh nmodulation change teh channels on teh router try using the 11>and 1 that will help to improve the speed
Posted on Nov 25, 2007
How do I slow down the speed on Facebook
Change the settings using the Control Panel, Device Manager, Mice and other pointing devices application. Here you can slow down the scroll speed click sensitivity.
Feb 06, 2015 | Acer Tablets & eReaders
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
HOW TO IMPROVE MY HONDA XR200R TOP SPEED THANKS.
To improve top speed,one solution is to change your gearing, via the chain and sprocket set up. To gain more top speed, you need to replace your rear sprocket with a smaller one, say about 5 or 6 teeth less. Also the front sprocket changed for a slightly larger one, usualy 1 or 2 teeth more. Note, that while doing this will give you a greater top speed, it will not make your bike more powerful. A power pipe, or aftermarket muffler would be a great improvement too.
Jun 21, 2010 | 2002 Honda XR 200
Dark exposure
Check your ISO setting...should be between 100 to 400 for normal pictures.Did you change your exposure compensation setting to something other than "0"? Is the aperture ring on the lens set to the "A" position?
Feb 23, 2010 | Nikon D40x Digital Camera
Why my 28v doesn't fully charge. when charging indicator light is red. there is 4 charge indicator. when it reach 2 green light comes on showing fully charged. you would use it for about 20 minutes and...
One or more cells of the battery have gone bad. The technique of measuring the state of charge of the battery is VERY limited.
I would recommend letting the battery cool after charging... THEN in a day, charge it again without using it. Do this for several days and see if the battery improves. If not, time for new battery.
DO NOT discharge these batteries beyond the point where the tool starts to slow down. You will reverse charge the weakest cell from the ones still deliveing power and the reverse charge will permanently damage the weakest cell.
Nov 26, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
My netgear router will not connect through wireless side only
Sorry I should have clicked on Full View befroe I submitted a comment.
Try resetting the Netgear back to the default settings. There is a reset button at the back of the Netgear rpress it untill the LEDs flash then release the button and then configure the router again.
Open a browser and enter this URL http://192.168.0.1
The login name is admin and PW is password.
Change the default password.
In the wireless settings change the SSID and turn off SSID broadcast.
Setup encryption use WAP2 or WAP
For added security enable MAC address filtering.
Then configure the computer's wireless card with the router's SSID and encryption settings.
Also check the wireless channels of the access points/routers in your area and set your router to an unused channel (or one that has the weakest signal strength) so you get less interference with your router.
Also move your wireless router away from walls and if possible raise it higher to improve the signal to your computers.
Sep 20, 2009 | NetGear WGR614 Wireless Router
Change settings
The router ports autosense the speed of the device that you are connecting to it. If your xbox is set to run 100 mb the ports will run 100, if the xbox is set for 10 then thats what it will run. Test the speed of your internet connection with a wired pc and then test directly into your modem and see what speeds that you get. You can test your speed here:
www.speedtest.net
Jun 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Acer Travelmate 290 model CL 51 How much Ram can I put in and continue to see a marked improvement in speed? It has 500 MB at the moment.
RAM's or Memory module cannot improve speed. It improves your memory capacity, The more Ram you have the smoother your applications will run. If You wanna see speed improvement, also upgrade your CPU, and Hard Disk Drives. Faster CPU and Hard Disk means faster processing and Data access and retrieval.
Jan 24, 2009 | Computers & Internet
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Jun 18, 2007 | NetGear DG834G Router
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
599 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
