Question about Exonic EXD7010 Car Video Player
I bought my vehicle used with the exd7010 and exonic drop down screen already installed. I received no remote or headsets. Only headset jacks I have are behind the center console of my 2004 Chevy Tahoe which receives the radio/cd player only. I think I may need the wireless headsets but not sure. Any help would be greatly appreciated.
I have the same unit and yes, there are wireless headsets that go with. the unit will also run through your radio,although mine keeps losing the signal and no one seems to have the manual.
Posted on Mar 25, 2010
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
When I plug CS55H into the splitter the phone says it is in use and I cannot receive any incoming calls.
CS55H wireless headset - There are a couple of things you can try to make sure there isn't some issue with compatibility between phone and headset. First, let's clarify some things: Is the CS55H being used in a home office with a single line? If not, is it being used with Avaya Partner telephones (only office system it will work with). On the Partner phones the CS55H works best through the AUX jack located on the bottom of the phone next to the telephone line input.
Now, the couple of things you can try. This may sound silly but make sure your phone, or any remote unit, is turned off. Second, disconnect the phone and splitter from the wall and connect the CS55H directly into the wall jack. Make a test call, with your mobile for instance, and the headset should alert you to the incoming call. If it works like it's supposed to, you may have to separate the two devices.
Good Luck from Headsets Direct!
Jul 20, 2011 | Plantronics CS55H Wireless Headset
I just bought microsoft lifechat LX 3000m but i can't hear any sound when i used it to listen to music or watch movie. it has been installed already
Windows 7? If so then right click on the speaker in the notification area in the bottom right hand corner of the screen select playback devices, and right click on the headset and select "set as default device".
Mar 05, 2011 | Microsoft LifeChatâ„¢ LX-3000 Headset
My Headset does´nt have dialtone, I was connecting to cisco phone 7941, 7970, 7911, and nothing, not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is not the best compatible solution. To use an S11 with a Cisco phone, you have to make sure that you are plugging it into the handset receiver jack and not the headset jack. You will need to lift the handset receiver, set it off to the side, and then hang it up after each call. If you want a more compatible solution that you can plug into the actual headset jack and just press the headset button on the telephone to answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
Plantronics 26716-01 cable
Plantronics H Series Headsets
Aug 12, 2010 | Plantronics S11 Headset
How do I get the headset, set up so I can use it. I plug it into my computer and nothing happens. Do I have to download something first? There are no directions with it. And if I have to download it, how...
There is no need to dodownload something. assuming that you have already installed correctly the audio card drivers. If you are able to hear sounds from the speakers, the audio card is installed correctly. So plug the green male jack to the green female jack and the red male one at the red female jack (if your headset has no mic, is only headphones, there isn't any red jack). From now on you must be able to hear sounds from the headphones and talk to the mic for someone to listen.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | Microsoft LifeChatâ„¢ LX-3000 Headset
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
How to use, bought used no manual
h500 only has 3 buttons the one on the face is power on/off/answer/hangup
and the two on each side are volume up/down that is all this headset will do
Apr 04, 2009 | Motorola Mobility H500 Wireless Headset
PLANTRONICS Headphone won't work with IP 501 sip, polycome phone
Dont plugged into the headset jack. Like Nortel, connect headset line with phone base unit in receiver jack and plugged your phone receiver wire into headset or plantronic base unit. This will work. I am sorry, my english is not too good but hope you understand it now. But the pully is not working properly with IP501..I mean it is not good to pickup IP501 receiver and put it back right place.
Dec 17, 2008 | Polycom SOUNDPOINT IP 501 SIP
Connect head set to sharp lc-26d43u tv
The audio out from those jacks requir amplification and will not drive a head set. Get an inexpensive stereo receiver and run the audio out of your TV to the receiver and use the receiver for your headset.
Jun 29, 2008 | Sharp LC-26D43U Television
Exonic EXD7010 Car Video Player Logo
204 people viewed this question
Top Exonic Car Audio & Video Experts
xxxxxx xxx
Are you an Exonic Car Audio and Video Expert? Answer questions, earn points and help others
