Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
My refer door will not stay shut - Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
  • 3,037 Answers
The door may not be sealing good. The rubber seal that goes around the door may have cracks or a hole in it and needs to be replaced if this is the case. Otherwise the hinges might be bent/broken and keeping the door from shutting. Does the door open right when you shut it and/or after a while does it open up on you?
Benjamin
Posted on Jul 22, 2009
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
Car Door Won't Close or Stay Shut - JamesMaurer.com
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Jan 16, 2016 | Cars & Trucks
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
Door springs
If the door won't stay shut the issue is with the door catch not the door springs, But if you want to know where the door springs are you need to remove the outer cabinet of the dishwasher and you will see them on the lower sides.
Mar 04, 2012 | Zanussi Dishwashers
Sometimes the brand new battery is dead, and sometimes it isnt. at about the same time this problem occured the passenger side rear door lost the power window and locks. sometimes the door ajar light comes...
System not 'going to sleep' causing parasitic draw higher than 25mA.
When you turn off your car the electrical system shuts down after 90 seconds to a low level draw of 25mA or less.
The door switch stays activated and rest of on-board systems stay awake too.
Need door lock sensor replaced and/or maybe window switch/es.
Have car scanned for faults with a VAG-COM scanner or simalar.
Check here for a local shop or reference or a VW specialist shop...http://www.iatn.net/shopfinder/
Jan 12, 2011 | 2004 Volkswagen Jetta
When I shut the door, the light stays on and the turntable keeps spinning, even though the microwave isn't on.
Issue with safety swich Door, and Relay Control on the main board ....Refer to Professional Microwave Repair ...Do not attemp to fix CAUTION HAZARD VOLTAGE INSIDE...
Sep 30, 2010 | Hotpoint RVM1435 Microwave Oven
Detergent dispenser will not stay shut so the soap power falls out before washing starts. Last time use I opened the door by mistake part way through the cycle. Could this have messed up the latch...
Opening the door did not affect the latch on the dispenser. The catch does wear out and can be replaced. This involves disassembling the door and a small jigsaw puzzle of springs and levers. If you are attempting I would advise taking pictures to refer to before taking apart.
Eric
Jan 11, 2010 | Kenmore Dishwashers
Rear door won't stay shut
Check the latch mechanism on the door. There is a piece of the latch that closes around the clasp on the door frame. sometimes this closes when the door is open and you can't shut the door. Take a screw driver and flip this latch piece open and close the door.
May 29, 2009 | 2008 Chevrolet Hhr
What would make the interior lights in my 2003 Lincoln Navigator stay on after it gets shut off? They will only shut off when you drive down the street, once you shut it off and get out, they stay on and...
you may have your dim switch on and this cause the lights to stay on but they don't stay on all night or day they have a 10 minutes delay switch after 10 minutes they go off but yes there is an open circuit can be a door can be the trunk or the dim switch look for it and try to find the source of this open circuit like a mention before it's on the doors or the dim switch
Mar 27, 2009 | 2003 Lincoln Navigator
Door open light stays on when door shut.
sounds like a faulty door switch not sensing that the door is shut. test the switches for continuity to determine the faulty switch
Jan 27, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
21 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
