Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
The refer door will not stay shut. food is going bad
  • erikjhn Jul 22, 2009
    The hindges are tight no wobble in the door sounds like the seal where do I get one? HD Lowes?
    Where can I get a seal?
    President:
  • 2,559 Answers
If the door is out of alignment,You will need to adjust at the hinges located at the top and bottom of the door.
If the seal is bad,you will need to replace the seal to correct the problem.
If you post more details,We may be able to help more.
Posted on Jul 22, 2009
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
Sep 08, 2014 | Microwave Ovens
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
Sometimes the brand new battery is dead, and sometimes it isnt. at about the same time this problem occured the passenger side rear door lost the power window and locks. sometimes the door ajar light comes...
System not 'going to sleep' causing parasitic draw higher than 25mA.
When you turn off your car the electrical system shuts down after 90 seconds to a low level draw of 25mA or less.
The door switch stays activated and rest of on-board systems stay awake too.
Need door lock sensor replaced and/or maybe window switch/es.
Have car scanned for faults with a VAG-COM scanner or simalar.
Check here for a local shop or reference or a VW specialist shop...http://www.iatn.net/shopfinder/
Jan 12, 2011 | 2004 Volkswagen Jetta
Sharp microwave door will not shut and the oven light stays on continuously.
The door has a switch , probably two, that engage and disengage when opening or closing. ( a failsafe so it switches off ) when you open the door, this is the problem also like a fridge the light should go off when door is shut, it may just be stuck but Dont mess with it , clean it if its got food stuff , a mild detergent round door etc , otherwise just change microwave ,
pete
Nov 10, 2010 | Microwave Ovens
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
