Cranky Deluxe Thomas the Train
SOURCE: Peg Perego Thomas Train Track Rider
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
SOURCE: Have lost instruction manual for THOMAS ULTIMATE TRAIN SET byTOMY
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
SOURCE: need Diamec 6V 4.5AH battery charger for Thomas the Train
For get the original over priced battery. You can purchase the same battery from the MFG! $8 and you can pocket the $60+ RIP-OFF
http://www.ebattery.com/Medical-Device/Diamec_DM64_BUP1013.html
SOURCE: dont know how to change the battery in Thomas Jet engine.
Hey. I was looking for the same thing and found this answer on yahoo answers:
"loosen the phillips-head screw on the underside front center of the jet engine train (you might not have noticed it - it is behind the coupling magnet assembly, which you can move to the side and also has an opening to access the screw) - once the screw is loosened, you can lift up the 'jet engine' from the base to access the battery enclosure"
http://answers.yahoo.com/question/index?qid=20071225073953AAHYJKb
