Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Water doesn't always go on floor and won't **** it up at all
Ive replaced this shampooer twice and this second one I've had tons of problems with it won't spit water on the floor then I unclogg it and it works but then it does it again now it won't **** up the water. This shampooer sucks I owned a hoover for 10 years never a problem till the last year the moter blew. I thought this would be a good product. What do I do ? I can't afford a new one.
    Problem Solver:
  • 8 Answers
You can take it to a vaccuum repair shop. Check your local yellow pages or go to bissell.com. Go under fequently askes questions. If you don't get help there call the customerservice number or e-mailthem. I hope that your problem gets fixed.
Posted on Jul 27, 2009
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
I just bought a bissell pro heat shampooer it worked the first time now it won't **** up water
go please to the web page:http://www.bissell.com/maintenance-tips/
and proceed according with the videos for troubleshooting+fix it.
God bless you
Aug 02, 2012 | Vacuums
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Ck
Aug 16, 2011 | Vacuums
I have a Bissell 2x Turbo 9300 shampooer. It won' spray from the carpet/floor position. I re-booted it and checked for blockage - nothing. I flushed the hand attachment and got it to spray some...
The heater is glogged trust me. It is the size of a dollar bill with seven screws. take it apart and clean the water path also take a small drill bit to the ports of the heater.
May 31, 2011 | Vacuums
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Will not dispence any liquid
i have the same problem. But my pump belt is broken. Ive oredered a new one so hope to receive that in few days. Not sure if it is linked though
Aug 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I change my kirby g4 to sweep/mop mode?
Turn the belt lifter to red arrows matching to sweep the kitchen floor. This stops the brushroll from turning and allows you to use straight suction. There is a hard floor pad available...see the link to my guide and you may find one for sale...
As for mopping...I just dump a small bit of soapy water on the floor and run my Kirby shampooer (with no solution in the tank) on the lowest setting to scrub, then I dry mop behind it to pick up the excess water. There really are no instructions in the manual for scrubbing linoleum, but I just improvised. It splashes a bit, but better than getting down on hands and knees. Here is a guide to hook up the shampooer...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps a bit...
Marci
Dec 12, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby Sentria
Your shampooer is not broken. (sorry Fanny)
You are missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box. Here's a link to my online Kirby shampooer instructions...
Hope I helped!
Marci
Nov 05, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Sep 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
131 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
