Water still in Maytag Washer
Old Maytag Washer (Model LA310) no longer completely emptying the water out
  • 55 Answers
Hello.
You will need to replace the pump on your unit. The part number for your pump is 6-2022030. This will fix your unit up and your problems will disappear.
Posted on Jul 22, 2009
My Maytag Washer model GTW460ASJ4WW empties as soon as water IS INPUT
Is water leaking on the floor? Do you hear it running in the drain? Drain hose should be as high as washer top, otherwise water will siphon out, if pump is running might electical issue. Try that first.
Sep 27, 2017 | Maytag Washing Machines
Tip
My Maytag Neptune washer takes longer than usual to complete the cycle.
Hi.
When the washing machine is working, takes an unusually long time to complete the cycle, that is not usually do to a control unit (CCU) fault, but to the fact that one condition needed to follow on the cycle is not met. The CCU may have to wait a longer time, and will not proceed to complete the cycle.
The most obvious thing to check are the water hoses, checking the drain hose and the inlets. If water is not coming with sufficient pressure, or if one of the hoses is blocked or kinked, the cycle time may take much longer than normal.
Other common problems are the pressure switch (SWITCH, PRESSURE), that detects water level, and the thermostat (on self heating models only).
The pressure switch determines when to stop filling and draining. If the pressure switch is faulty, then drain and filling may take much longer or go on forever.
Check also that water valve and dispenser valve are not clogged. (VALVE, WATER) and (DISPENSER VALVE )
On the water valve there may be a thermistor (not all models), check that the thermistor contact is not disconnected (WATER VALVE W' THERMISTOR) , as the thermistor may also be faulty.
Click here to find all replacement parts and diagrams for your appliance.
Regards.
Ginko.
on Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
The pipes froze and busted in my garage which cause water to burst in my Maytag Neptune front loader washer Now the water won't drain Please help
That machine has an electric water pump, The first thing I must ask is has it completely thawed out? There is a rubber hose that goes from the tub to the pump, if the water in the hose is still frozen in the hose or in the drain hose, it will not empty itself.Also the water water level switch is in the top of that hose. Another possibility, is the pump or the water level switch could be damaged. You can access the pump by taking the front panel off. That is not hard to do, requires removal of the door and a couple of other screws.
Mar 07, 2015 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag dependable care plus washer model # LAT8714AAL It must be old because I can't find any info on it at all. I need to know how many gallons of water it uses per fill up on the xtra large
The amount of water is determined by a float so it will vary based upon how much is placed into it. One way to, find out, is to fill it empty and measure or calculate it . Even the new maytag models do not tell specify how much water is going to be used.
Jan 14, 2015 | Maytag Washing Machines
I find water in the washer when not in use
most washer do not completely drain all the water out, this is why you should run an empty wash cycle with a gallon of white vinegar in your washer.
Jun 25, 2014 | Maytag EPIC MFW9700S Front Load Washer
I have a Maytag Neptune washer (model MAH5500BWW) that won't completely drain. It goes through the normal cycles but, but water still remains in the tub. Could the pump be out and how can you tell if...
Check the pump out flow of the drain hose, is it a good strong flow or does it seem weak and restricted. If the drain is slow the machine will stop before it is empty. Also if the drain hose is not vented, mounted too high in the air, or has a piece added on making it longer, it may degrade performance.
Mar 14, 2012 | Maytag Washing Machines
Maytag series 100 dishwasher not completely emptying after cycle
I am having trouble with water not emptying out of dishwasher completely help
Jan 07, 2010 | Maytag Dishwashers
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
My Maytag Neptune fnt loader Model# MAH8700AWW Ser# 12227145GR
I have the same problem. The technician seems to think it could be the water is not emptying during cycles. It keeps adding water as the cycles continue and therefore over flowing the tube when it spin. He thinks it could be a water level sensor. Not sure at this point.
Feb 27, 2009 | Maytag MAH6500 Neptune Front Loading...
Wash cycles are increasing in time required to complete
cold water valve in back could be plugged causing longer fill times.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
