Question about Black & Decker String Trimmer Cordless 12" 18V
Brand New B&D 18v trimmer and string breaks off right away
You can go out to trim, and it keeps feeding itself out till nothing is left in a couple of minutes. Called B&D and they said it could be the white thing inside where you install the line that is touchy, so they sent another one, but still same problem. What am I doing wrong??? Is there a trick or something???
  • 4 Answers
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Posted on Aug 07, 2008
  • 12 Answers
SOURCE: 12 volt grass trimmer/string breaking
Just a reminder, do not use cordless string trimmer as heavy work.
Posted on Aug 30, 2008
#1 Taper
  • 1040 Answers
SOURCE: only 1 string trimmer /// string keeps feeding when running
You have the string wound the wrong way on the spool.
Jim
Posted on Jun 17, 2009
  • 133 Answers
SOURCE: GL 320 String trimmer - nylon string keeps breaking
It sounds like the sting is wound backwards. Try winding a short piece in the opposite direction. If it is backwards, it will be gone in a hurry.
Posted on Apr 20, 2010
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
The strings keep on breaking off at the eyelet
Usually means grass is too long for that trimmer or you are cutting too close...try trimming with just the tip of the cord...or eyelets are worn sharp
Aug 08, 2010 | Ryobi 18v Lithium Grass Cordless Trimmer...
String Runs Out
You are most likely keep bumping the head on the ground, causing the string to unwind. Hold weedtrimmer off the ground.
Jun 02, 2009 | Black & Decker String Trimmer Cordless 12"...
How do I get my Black and Decker 12"bump feed trimmer/edger out of the groom position and into the edge position? My boyfriend misplaced the instructions to our new edger and I can't figure it out.
The handle/shaft is in two parts. By grasping the upper part of the shaft with one hand, and the lower part with the other, you can move the two sections slightly apart, then twist to turn the trimming end 180-degrees.
Sep 15, 2008 | Black & Decker String Trimmer Cordless 12"...
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Restring 14" electric weed trimmer? string keeps breaking
I just assume you used stronger line on an autofeed string trimmer.
Aug 17, 2008 | Black & Decker String Trimmer Cordless 12"...
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Don't know how to rethread the line
Breaking off is a normal process. Set the centre of your line in the spool and wind the two strands in to the Spool, thread and re assemble. C
May 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
110 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
