Question about Carrier 38CKC036 Air Conditioner
Fan doesn't turn
It clicks when it turns on... but nothing happens after that
    President:
  • 1,124 Answers
Are you talking about the outside unit ?
If so - it could be the capasitor or it could be the fan motor..
Posted on Jul 22, 2009
Fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Take it out and see if the fan wil turn by hand. It may have somethng obstructing it. The clicking is the motor overload. It wil burn out if it continues to keep clicking.
www.dimplex.co.uk/assets/.../Cadogan_Stove_Instructions_Issue_2.pdf
Jun 29, 2014 | Heating & Cooling
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
Craftmade Ceiling Fan Problems
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
Jun 15, 2013 | Craftmade International CXL52 Electric...
2002 cadillac escalade engine doesn't crank
From your description, it could be a defective ignition switch
Nov 12, 2012 | 2002 Cadillac Escalade Base
Projector will not turn on. The power light is solid Blue and clicks every minute or so like it is trying to start but nothing happens. It has happened to two projectors. I am baffled as to the solution....
I too have to same problem, did you find a solution? I swapped out the existing fans with different ones to try to solve the problem to no avail. I inspected the bulb for signs of malfunction and could not find any. Any updates would be wonderful!
Aug 21, 2011 | ViewSonic PJD6531W Projector
95 buick regal two fans in front , one make clicking noise after vehicle turned off. Its continues to spin and makes a clicking noise after turning off engine
It is normal for the fan to stay on after the engine is off. The clicking is not. Once the negine is cooled down and the fan is not running. check the fan by spinning it and try to locate the clicking noise. Make sure the fan doesn't wobble. If it does then the bearings are going out, replace the fan. The clicking could be something lodged in the shroud, clicking against the fan blade. Like a stick.
Jul 01, 2011 | Buick Regal Cars & Trucks
Directional Lights
First check the fuse, then the flasher. If it still doesn’t work you will check the relay. Finely and more difficult is the turn signal switch. This involves removing the steering wheel.
Jul 05, 2008 | 1999 Chevrolet Lumina
Carrier 38CKC036 Air Conditioner Logo
134 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
