Question about Canon PIXMA iP3000 InkJet Photo Printer
Bad colors in print
I didn't change one of cartridges in time after this I started to get bad
quality pictures. Even after I changed needed cartridge quality is still bad.
Please, help!
    Problem Solver:
  • 18 Answers
Perfrom a deep head clean 2 times this will clean the printer printer head out. make sure u have heaps of in in your ink tanks as it uses a bit of ink to clean the heads out. then try and do a print. also you may need to do a head alignment on the printer. this head alignment should be done after u replace ink tanks.
the only other item it could be is the print head on the printer.
Posted on Dec 06, 2007
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
I have a Samsung CLP-620ND color printer, only 1085 copies printed. After changing the 3 colored toner cartridges, my print out came out bad. Left side of paper around 3
Dear
Open the individual carts from the printer and visually observe the density of toner on the developer roller evenly. Some times the cleaning blade of ITB over come the problem.
Before this try to adjust altitude and cleaning on EPM or smart panel from PC.
Thanks.
Mar 15, 2012 | Samsung CLP620ND Colour Laser Duplex...
I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
That's why I suggest you to but even cheap compatible cartridges and replace them.
Hope this helps. Alex
Sep 11, 2011 | Canon Office Equipment & Supplies
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
Just changed the black ink cartridge but black color still doesn't print. First time had this problem.
Try exchanging it for another. Sometimes you get a bad one from the factory. Will it still print from the old cartridge (even if poorly)?
Jan 01, 2010 | Canon Multifunction MPC-370 Printer
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
Kodak Easy Share 5100 will not print after I changed black cartridge
Press copy and photo at the same time and print a demo sheet. Look at the eyes of the two kids in the picture, if they look like zombies, your printhead is clogged. try cleaning the printhead and print the demo again. If it's the same, you need a new printhead. Call Kodak.
Oct 08, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Changes color when printing
your other color cartridges are running nearly empty, perhaps. if only 1 cartridge in this machine, the same thing has happened (multi-chambered color cartridge)
May 31, 2007 | HP PhotoSmart 7150 InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
104 people viewed this question
old marine
old marine
