Question about HP PSC 2355 All-In-One InkJet Printer
Pickup roller does not grab. - HP PSC 2355 All-In-One InkJet Printer
  • 94 Answers
You need to clean your printer properly dust particles cause its malfunction
Posted on Jul 22, 2009
HP M2727 paper starts to pick up and apparently jams just above the paper tray #2.
http://www.amazon.com/HP-P2015-2015-Roller-Maintenance/dp/B00965WQYI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1377471140&sr=1-1&keywords=rk-p2015Hello,
It sounds like the pickup roller is not getting a good grab on the paper. When this happens the roller can not push the paper up into the printer where the next rollers can grab it. this is a very common issue after a year or two of use. The pickup rollers and separation pads come in a kit that is available on Amazon here: http://www.amazon.com/HP-P2015-2015-Roller-Maintenance/dp/B00965WQYI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1377471140&sr=1-1&keywords=rk-p2015
Aug 21, 2013 | HP Laserjet M2727nf Multifunction Printer
Printer shows jam when there is none, press the check and it prints OK
That type of problem is called a phantom paper jam and is caused by the printer not picking up the paper like it should. When the print job is sent to the printer the pickup rollers turn and should grab the top sheet of paper and feed it into the printer. When the rollers get worn down and slick they can not grab the paper right so you get the error message. When you retry the rollers may be able to grab the paper and the job goes through. To correct this intermittent problem you will need to replace the pickup rollers and separation pads. This is easy to do for the end user no need to send the printer in for service. Here is a link to the roller kit needed for the HP Lasejet 2420 printer:
http://www.ccl-la.com/catalog/product_info.php?products_id=304
Mar 05, 2013 | HP LaserJet 2420 Printer
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
My copier will not pull the paper through to make copies it seems to want to jam -up ,when the paper start through
There are a couple of possible issues here. First, if the unit isn't new, the paper pickup rollers may have picked up 'chaf' from grabbing paper which over time reduces the ability of the rollers to grab paper. The 2nd option is that if the copier is older, the pickup rollers have dried up which reduces their stickyness and ability to grab paper. The 3rd option is that if you live in a very humid climate, the paper may have absorbed humidity, which can keep it from curling in the correct direction as its being pulled through the printer/copier.
Jun 20, 2011 | Computers & Internet
Canon 6551 copier-rollers are grabbing causing smear on the copy
check the paper path you need to control the main drive mecanism, and all bushing roller : registration roller, pickup, fixing and exit: you can see exemple of the bushing to check: mabroukmedal_41.jpg
the roller that you need to check and replace the bushing:
Dec 21, 2010 | Canon NP 6551 Black and White Copier
Rollers will not grab the paper through to fax or copy. Please help!
You need to go and order the bottle called "roller rejuvination solution) from the website fixyourownprinter.com.
Cost under $20.00 and all you need to do is dab a qtip some of the solution and spread the solution from the qtip onto all the roller pin paper pickups.
Wait 10 minutes for it to dry and then test the fax again. It will now pick up single sheets afterwards.
Mar 19, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
HP LaserJet 2430n is not grabbing the paper like it used to
You need to replace either the pickup roller or the separation pad (or, optimally, both at the same time) - both should be removable without tools, they just snap in. You can order new parts at http://partsurfer.hp.com - shouldn't be more than $20 worth of parts. You can help reduce the problem slightly by roughing up the rubber on the pickup roller and the cork on the separation pad by scuffing both with a light grade of sandpaper, just to give it some tooth. But replacing them is best, it'll fix it!
Oct 20, 2009 | HP LaserJet 2430dtn Printer
The printer won't grab the paper. It worked fine
I had the same problem. The paper wouldn`t lift for the pickup roller to collect it. Just loosen the paper width guides and that should work then.
Delboy
Apr 29, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Printer Grabs Two sheets of paper at one time
there is a pickup roller & seperation pad that are either dirty or worn out, you can clean the roller with a small amount of alcohol 99% solution and cotton swab or lint free cloth.
Wayne
Jan 09, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2355 All-In-One InkJet Printer Logo
152 people viewed this question
Seeker5211
Seeker5211
