Question about Motorola Mobility HS820 Consumer Headset
HS820 "dead"? No blue light
Hi! I thought my HS820 needed a charge, as it would not power on when pressing the MFB for 30+ sec. Plugging in the charger, no blue light to indicate charging :-( I read in the manual the batteries will wear down after time and should be "disposed properly". Think the battery(ies) are dead? How would one get a replacement or change it? Have also emailed Motorola. Thanks!!!
  • 2 more comments
  • Anonymous Nov 28, 2007
    My hs820 blue light comes on when on the charger--when light goes out indicating it's charged I cannot turn it on for normal usage.
  • tonyturbo Jan 05, 2008
    bought my hs820 with no instructions, when on charge blue light is on, when not on charge it refuses to do anything. wont light up.
  • Anonymous Mar 27, 2008
    PUSE A CARGAR EL DISPOSITIVO Y DE REPENTE LA LUZ AZUL NO ENCENDIO MAS... OPRIMO EL BOTON PRINCIPAL POR MAS DE 10 SEGUNDOS Y LA LUZ NO ENCIENDE Y TAMPOCO SI LO CONECTO NUEVAMENTE... LLEGO AL SU FIN DE VIDA UTIL ?
  • Des and Gab Jun 26, 2008
    I've tried to charge the battery but no light will come on and it won't work.
Toss it. They aren't replaceable. You have to break open the case (glued shut). Even if you opened it, the replacement would likely cost you what it would to replace the whole unit.
I'm in the same boat.
Posted on Nov 26, 2007
My 2 year old galaxy tab 4 won't charge
Disconnect charger
Hold power button and volume up button for 30 seconds
Keep holding buttons while plugging in charger
Hold buttons for another 30 secs
Release power button keeping volume button pressed
Tab starts to charge
May 22, 2017 | Galaxy Computers & Internet
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Lost manual for BTH-03B1 where can i get a copy as need the factory setting pass code to use it again as will not register again
The headset has two buttons, one big (MFB) which does multifunctions inc volume + and one small which does volume -
To pair start with headset OFF and have your handset within 1 metre.
Press and hold the MFB for 8 seconds until the headset LED flashes red and blue. Its now ready for pairing.
Activate your mobile Bluetooth function to find and select BTH-03B1 from the list.
Enter the passkey "0000" when asked
When pairing is completed the LED will flash blue every 3 secs in standby mode.
To operate in use use the MFB to increase volume. You also use this to answer calls by press for 1 sec. or end call by pressing for 3 secs.
You can do headset to handset/headset and use the small button by pressing 3 secs to transfer.
Feb 06, 2010 | Radio Communications
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Blue light on
i opened it,the upper part does not detach completely but slides,the blue light turned off finally but then on pressing the button nothing happened.Now i'm charging the battery and the blue light is on as usual so i hope it's just out of energy and it will work again when recharge will be finished:)
Aug 21, 2008 | Motorola Mobility HS820 Consumer Headset
HS820 won't activate 'voice dial' on Blackberry Pearl
Did you find a resolution.  This is the same problem I am having with the Curve.
May 22, 2008 | Motorola Mobility HS820 Consumer Headset
Light always ON!!!
hold the button and wait till the light blinks twice and it will turn off
Jan 29, 2008 | Motorola Mobility HS820 Consumer Headset
CANT CONNECT BLUETOOTH TO MY PHONE
  • Start w/ power off (Best way to make sure you are off is to plug the headset into the charger for 1 minute, then unplug & wait 10 seconds before continuing.)
  • Press & hold MFB. DO NOT RELEASE YET.
  • light will flash quickly a few times to indicate power on. (Still holding MFB)
  • After a few more seconds of holding the MFB the light should glow steady.
  • Once the light is on steady you may release the MFB and pair with your phone.
good luck
Jan 02, 2008 | Motorola Mobility RAZR V3
Motorola Mobility HS820 Consumer Headset Logo
754 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
