Question about Pure Digital Flip Video Ultra Camcorder
I am charging my new Flip Ultra HD battery pak for the first time. The charging light is flashing, non-stop. I thought the light was supposed to NOT flash while charging. Also, should the camera screen be lit up while charging? If I need to charge the battery pak for 7 hours (as per the instructions), won't this be bad for my camera screen to be lit up for so long?
1) remove the battery pack from the camcorder
2) connect the camcorder to a powered USB port on your computer
3) when the "Connected" indicator comes on, insert the battery pack into the camcorder
4) safe eject your camcorder from your computer
5) reconnect your camcorder to your computer
6) the battery pack should now begin to charge within the camcorder
Posted on Oct 03, 2009
I had the same problem with the light flashing instead of staying steady, I called and the help desk said this "should not be a problem". I then wondered if my screen was on as yours is while charging. I can't see the screen because the flip is screen down while charging. I lifted the computer up to look at the screen and saw a notice on the Flip's screen that said "It's really hot, charging paused". So, I'm assuming the flashing light is to inform you that the charging has been paused and maybe you should disconnect for a bit to let it cool off. I'm letting it cool off as I write this so I'll get back here if there is any further news.
Posted on Jul 26, 2009
I cut the plastic wrap on the battery pack to reveal the fourth battery end.(2 batteries, 4 ends) and it's working.
Posted on Dec 28, 2009
What I see is:\r\n1) That`s not the temperature of the battery pack that is high
2) There is a high over temperature in the plug of the USB when we get the alert
3) The little sensor of the temperature of the pack is "feeling" the temperature of its cristal liquid screen. (you can see it near the (+) jack. up left side)
May be if we transpose this sensor to the very botton of the inside of the camera batt pack place. So maybe it will read the correct temperature of the batterypack whiling its been charged.
Posted on Nov 18, 2009
I tried all the"fixes" for the battery problem but none worked.
I love the camera so I emailed Amazon asking if they would give me a
credit for the defective battery or I would return the camera.
Amazon gave me a $30 credit to keep the camera as opposed to returning it.
Using my own AA batteries is fine with me.
I'm so sorry to hear your Flip UltraHD Camcorder arrived damaged. This usually doesn't happen.
If you're interested in keeping the Flip UltraHD Camcorder, I'd like to offer you a refund of $30.00,
which is 20% off the price. To accept this refund, let us know and we'll issue the refund to your Visa.
Please visit the following link to provide the information we requested:
Posted on Jun 18, 2010
It's really not a fix... but my NEW camera did the same thing... I put a box under it and it seems to be charging... a box under it so it's not hanging on the USB.
Posted on Jul 23, 2009
  • maplecreek Sep 03, 2009
    I forgot I posted something here...
    First Unit...
    Let me first say I love the HD quality of the flipUltraHD BUT I could never get the battery to charge after the first charging of 1 hour.. I called the flip helpdesk and they ran me through a bunch of things... nothing seemed to work.. it would either charge 1 hour and then give me the Hot error message or charge for 10 seconds.. they recommended I contact seller and get replacement. 2 weeks later I got a whole new unit and new batteries.
    Second Unit...
    Still love the HD quality... but after 3 hours of charging started getting error message... came on about every hour.. suggestions from flip helpdesk charge with cover off.. I found out if the room or area where the flip was charging was cool then it would charge a little longer.. not a good fix... asked rep if it's suppose to be able to charge in one sitting... answer yes... and she told me that i should try the minoHD.. not an option because i liked the idea of AA batteries and the larger screen..
    anyway tried to work with limitation and ended up returning item for refund.. battery problems too much for this mother of twin toddlers to deal with.. going to save up and get a small HD hard drive video camera... about $200 more but *crossing finger* hopefully it won't have the battery problems I had with the flip.
    oh yea with both units i tried using the USB flip cable, the wall unit and all ports on my computer to charge it... all of which would error out with the hot message... again the rep said that it should not be getting that error message and suggest to try the miniHD a little cheaper and her kids used her's all the time and it charged with no problems.. hmmmm...
Remove the camera from your computer or from the charger. Let it cool. Then, charge again. Remove the cover of the camera to allow more air to cool the batteries while charging. Flip explains how here:
http://www6.nohold.net/CiscoFlip/ukp.aspx?vw=1&docid=bca98f5d36b74526a872a38bf805f6e9_Camcorder_Flashes_an_Overheating_Message_While_Charging.xml&pid=2&respid=0&snid=3&dispid=0&cpage=search
Posted on May 14, 2010
I have a flip slide hd S1240W that has not been charged up in a long time. I have tried to charge it and attempted to reset and then charge. All that is happening is a red flashing light but nothing at...
Try removing the batteries, plugging into your computer, popping the batteries back in, and removing. Wait 5 minutes, and plug back in! This should have an affect!
Oct 06, 2013 | Flip Video SlideHD S1240W HDMI Camcorder
I just bought my 11 year old an ultra hd 2 hr flip video, we cannot even get it to power on, any suggestions?
You need to first Charge your camcorder battery pack.(mine had to charge over night) the first time.  Plug the little arm that extends from the camera into a USB 2 port on your computer and make sure your computer stays ON during the charging, otherwise the camcorder will not charge.
A red light will come on during charge and goes off when charged. If it does not come while plugged in try a different USB port.  Screen should light up temporarily and Red light showing charging on front of camcorder.
IF YOU HAVE ALREADY DONE THE ABOVE, and are having the problem, pull the battery pack out and reseat it back in there again.  maybe connection not good.  OH, and I think mine had plastic covering the metal connections you may want to check that too -remove if so----- BUT the entire white plastic around the batteries STAYS IN PLACE do not remove that.
If that still doesn't work I would try regular AA batteries in it if in fact you have The FLIP ULTRA HD it will take regular batteries too.    IF they work - then maybe you got a defective Rechargeable Battery pack and should contact Flip Video at   http://www.theflip.com/en-us/
Feb 13, 2011 | Pure Digital Flip Video Ultra Camcorder
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
Oct 11, 2010 | Pure Digital Flip Video Ultra Camcorder
Have a new Ultra HD Flip Video. How do I know when it is fully charged? Does the red light go off or what?
Hello there,
The Flip Ultra should have a rechargeable AA battery pack.
To verify it is charging, the battery icon will be flashing lightning bolt. The red light goes from red to green the moment it is fully charged. It takes six hours before it gets a full charge via the USB.
Please let me know if this gave you enough information. Thank you for using FixYa.
Oct 08, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip videp ultra hd - red light blinking while charging
i have the same problem too. whenever i try to charge it through the dock. the red light continuously blinks and it won't charge.
Aug 22, 2009 | Flip Video Flip UltraHD 8GB High...
My Flip Ultra HD won't charge or upgrade.
What about if I can get it charge, full green bar, but it won' turn on. Then after some time messing with it, I get it to charge again and the battery is empty again. Any ideas???
Jul 31, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip ultra hd not charging
I had the same problem, but it seemed to be a bit more sporadic. I'd occasionally get the "Charging Paused - Check Battery Pack" error. The battery pack itself looks a bit strange, since the white plastic covers the bottom, right side and it seems that there is no possible way for the battery to make contact with the camera. However, I saw the following suggestion on another site (which the poster claimed came from Flip technical support), and this technique worked for me:
May 20, 2009 | Pure Digital Flip Video Ultra Camcorder
Camera software corrupted??
I had the same problem with my flip mino HD. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Apr 13, 2009 | Pure Digital Flip Video Ultra Camcorder
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip video won't charge
If you look on the bottom of the camera there is a button that slides from a locked to an unlocked position. Slide it to unlocked and then slide down the back of the camera (the side with the lens) there is a removeable rechargeable battery pack. Remove it for a moment and then put it back in. Try plugging back into the USB port. This should work.
Jan 09, 2009 | Pure Digital Flip Video Ultra Camcorder
Pure Digital Flip Video Ultra Camcorder Logo
11,054 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
