SOURCE: I can't get the clutch cover back on
FUNNY THIS HAPPENS ALL THE TIME ,YOU HAVE TO PULL IT BACK,THE BRAKEBAR I MEAN, THEY CAN BE REALY HARD TO PULL BACK I HAVE NEVER KNOWN OF ONE TO BREAK BUT THEY CAN BE HARD TO SO MUSCLE UP AND AWAY YOU GO
Testimonial: "Thanks, the local Ace Hardware had a wrench welded up a while back because so many ditzes like me can't get the brake off before removing the clutch. "
SOURCE: chain brake band will not release to replace the clutch cover
Hi there
Sometimes that's not an easy job . I work for a Husqvarna dealer and I have that problem frequently . First try to get the clutch cover on place (do not use the bolts) and push in @ the top part of the clutch cover , then try to move the clutch lever backwards to release the band (better if done with two people) . If that does not work the only way is remove the clutch lever with the 2 bolts on each side and put the lever on the clutch cover (top metal piece that looks like a clover)to release the band (again with 2 people one holds the clutch cover and the other one the lever pulling the lever backwards) .
Hope this help
Hope this help
SOURCE: How to replace chain on McCulloch chain saw
The chain brake is engaged. support the cover firmly (as it will require a lot of pressure to pull the handle) and pull back towards the operator. When it is re-set, it will then fit properly to be assembled to the saw.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Testimonial: "Fantastic! I was pulling the handle to try to get it unengaged, but wasnt applying enough pressure. I had to apply quite a lot of force to do it. Thnx"
SOURCE: how do i release the clutch band to replace chain
Husqvarna - IPL, 235, 235e 240, 240e, 2008-01, Chain Saw (example - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
See Detail A or B (same pn), pn 503 057940. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 057940 in the upper left rotate it CW until it nests, to reset it.
This works quite well:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: I am trying to replace the chain on my saw. When
Your chain brake mechanism is in the "locked" position...you will need to release it. Some husky's have the handle on the cover. If this is the case simply pull the handle towards what would be the rear of the saw and install the cover.
Other saws have the handle on the saw and some little cogs mesh with cogs in the side cover. In order to unlock this one I use two 1/4" x 2 1/2 inch or so bolts in a vise. They get clamped with the bolts protruding vertically above the vise jaws and are spaced so the the tips of the bolt will fit in between the cogs. Study the assembly and determine the direction of rotation required to release the brake. Place the side cover face down over the bolts with the bolt tips in between the cogs and rotate until the brake cams over and releases. be sure you know which direction to rotate the cover as a bit of force is required to get things moving.
Once the brake is released you should be good to go.
Take care.
