Question about Nokia 6120 classic Cellular Phone
Have exactly the same thing happen... no idea what to do
Replaced the screen, connected it up nothing happens, just a white back ground, what am i doing wrong?
  • Nokia Master
  • 805 Answers
May be ur display ic or diod has damaged as a result it cann't capability to output colour. or if that ok so u need to change display
Posted on Jul 23, 2009
Won't start or crank
Ground connection gone? specifically ground strap from engine to chassis...
Jul 08, 2015 | 2000 Honda Passport
My Thinkpad X60 just stopped working today. I installed some new ram and when I turned it on the screen was just white and nothing else happened. I put the old ram back in but the same thing happened, just...
hi, put ur old ram press power button whyle booting
hit (F2 or dell) to inter bios then save & Exit see if
working same thing do with ur new rame .......
Jan 31, 2010 | Computers & Internet
My nokia 5800 has frozen on the nokia screen with white backgroun
The same thing was happening to my phone. I removed the battery, sim card, and memory card. I then replaced the battery an turned the phone on and it loaded to the main screen. I turned the phone back off and put back in the memory card and sim card and then it worked. Hope this helps.
Nov 18, 2009 | Nokia 5800 XpressMusic Smartphone
Something is wrong with the display on my Kyocera Strobe K612B. When I open and close the phone sometimes nothing happens but sometimes one of the screens gets distorted. The outside screen is usally the...
This EXACT same problem happened to me and I had to pay $50 to some cell-phone repair guy to replace the whole front piece of the phone....I HATE Kyocera and will NEVER buy ANYTHING from them ever again!
Aug 15, 2009 | Kyocera Strobe K612B Cellular Phone
I think wiring problems turned my Estate dryer into a brick.
The dryer has a jumper wire that goes from the center terminal to the case of the dryer, probably a white wire like you are talking about. When you put a 4 prong cord on, the piggy back he should have been talking about would be to take that white wire and put it back to the center pin and piggyback it with the white from the cord. Then the green wire from the cord should go to the green screw grounding the case. The idea is to seperate the grounded case from the neutral wire. With a 3 prong cord the ground and the neutral wire are the same and the neutral is tied to the case. I think it should have ran and heated for you the way it was hooked up. As long as you had the red and black on the outside terminals and the white or green in the center, it should have ran and heated. You probably have a blown fuse or bad breaker. Best thing is to check with a voltmeter and you should have 220 volts across the two outside terminals and also make sure you have 120 volts from each outside terminal to the center. You can chase your tail all day though without a meter to measure the voltage.
Jun 19, 2009 | Estate Dryers
Casio qt-2000 dead !
Did you let it stay like that for 5 or 6 minutes to see if it reset or did you shut it back down immediately? Sounds like you did nothing wrong, I mean what if the electricity went out it would be the same thing as what you did...if it did fry something would it happen to still be under warranty? A power surge would have produced the same result.
Mar 11, 2009 | Casio Parts Cash Register PC Desktop
When using the phone, it flashes white and drops the call or deletes the message
the exact same thing is happening to me. I have to go to tmobile and get a replacement.
Oct 15, 2007 | Motorola Mobility RAZR V3
Phone says "charge complete" but then just dies
I took your suggestion and replaced the SIM card, but the difference is I managed to locked it in tightly. It worked.
Aug 21, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Nokia 6120 classic Cellular Phone Logo
59 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
