1992 Chevrolet Cavalier Logo
Posted on Jul 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dim headlight don't work but bright does and bulbs are ok
Anonymous
Level 3:
  • Master 1,623 Answers
  • Posted on Jul 22, 2009
Anonymous
Master
Level 3:
Answers
1623
Questions
0
Helped
828826
Points
7074
Several things on your cavalier could cause this to happen...
If it's just your high-beams, low-beams, or DRL that are out (just one), start with the DRL relay (in the fuse box). If that's not it, and it's not the DRL, try the multi-function switch (the thing attached to the left of your steering wheel, the headlight switch/cruise control switch). If all that checks out ok the next place to look under the hood... there is a pin-out connector/harness under the battery box (located in the front on the driver's side) that may be corroded. It is attached to the underside, and not easy to see without a mirror. If there is corrosion on the battery box, this connector is probably corroded as well...anything that runs off the battery will find it's way to this connector.
Note for anyone else that reads this: Different people will experience similar problems, sometimes with the low-beams, sometimes with the highs, because of different corrosion patterns and the DRLs being run from different bulbs.
Good luck...i hope this helps, please take time to rate me a fixya.
Anonymous
Level 3:
President:
  • Master 1,865 Answers
Anonymous
Master
Level 3:
President:
Answers
1865
Questions
0
Helped
598898
Points
5720
If the low beam doesn't work, the bulb is burned out. You can verify this by checking for 12 volts at the low beam bulb socket
5 Related Answers
Anonymous
  • 158 Answers
  • Posted on Feb 24, 2009
SOURCE: Headlights won't go on; brights, parking lights OK
Hello,I see you have a problem with your low beams inoperative.It sounds as if your multi function switch has either gone bad. If you will dim and brighten your lights the switch may go back to working. You have to shake it in all directions. If they come back to working you will want to replace the switch as soon as posible on this car. Please rate this answer, Thank you.
Anonymous
  • 147 Answers
  • Posted on Apr 07, 2009
SOURCE: Headlight one side works on bright the other side works on dim
Try swapping the headlight bulbs or buying a known good bulb and testing that way. Sounds like a shorted bulb filament issue.
Anonymous
  • Posted on May 11, 2009
SOURCE: 2004 Cavalier Day/dim lights not working
I finally got mine fixed!! It was the crossover wires between headlights(the wires that run in front of the radiator). One wire was torn into. Spliced them and taped back together. Hope this works for you!! I also used something called wire caps that help hold the spliced wires together. I found this solution on yahoo.com search engine where someone else had suggested this. My only problem was no dim lights, but all the other lights worked fine.
Anonymous
  • Posted on Nov 12, 2009
SOURCE: headlight problem
Hello Donald,
I have the same problem now, have you found a proper solution for this?
Boneebone
  • 973 Answers
  • Posted on Aug 11, 2010
SOURCE: one headlight dim one headlight bright DRL doesnt
The dim headlight has a bad ground or bad wire, trace the black wire to a point where it mounts to the frame of the car and look for a broken, damaged, corroded wire. Repair and clean as needed.
2answers
Driver side headlight goes dim on high beam while passenger side is bright
bad connection or bad earth check all connection or bulb
While drivig my headlights get bright then dim
It sounds like a possible problem with you alternator not providing enough volts/amps to keep the lights steady. If it one light, it could be the bulb going out - buy a bulb from your local auto shop and try that. If it is both lights, you should have your alternator and battery checked at a Toyota dealer, local repair shop or if your handy with tools and don;t mind the work, pull them out yourself and take them to a local autoparts shop where they can test them for free. If either fail the test, replace them.
Headlights wont work on dim, only bright
Check your head light bulbs, your truck has the dual filiment headlight bulbs one per side which does both high beam and low beam, 9007 bulbs.
If the low beam filiments are burned out only the high beam will work.
Also look into finding out if the headlight switch is gone bad.
The headlight module and or drl module maybe defective.
Both headlights stopped working in the dim position, but they work in the
both headlights might have dim blown out buy a new bulb and see
Dim lights
I had the exact same problem. Everything checked out ok at the garage including the earths. Finally we discovered that it is very easy to push the bulbs in in the wrong position and they will work but they are too dim. There is only one way that they are supposed to fit in, as soon as we got them slotted in correctly - bingo, dazzling headlights!
2answers
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
