Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
My computer doesn't recognize seagate freeAgent external harddriv
When I plug in hard drive, the light on the side comes on, I can hear it running, but then it does nothing. I have had the hard drive for 2 years, and this is the first problem I have had. I have all my photos on it. HELP PLEASE!!!
Try another pc, mine won't work on one machine however works on another. Weird I know, but mine is brand new so I believe it to be my computer, not my drive.
Posted on Oct 21, 2009
    Scholar:
  • 51 Answers
It sounds like your hard drive is all locked up my friend. Unplug it now to prevent further damage. Don't worry any many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Posted on Aug 31, 2009
2 Suggested Answers
  • 1738 Answers
SOURCE: I have a seagate 500gb freeagent external hard
Windows 7 probably don't recognize it. keep an eye out for it at the manufactor website, for a driver. Windows 7 is turning out to be like windows vista
Posted on Nov 21, 2009
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
Externalseagate 250go not open how to solve
If you cannot open or see the harddrive when you connect it to your computer after it is powered on then that is the external harddrive itself. First, check if the power connection is connected and the usb cord connect correctly. Then see if any lights come on on the external hard drive. If lights does come on and still nothing showing or coming on to the computer, then your harddrive is history. Seagate makes one of the worstest hardrive. You can google this up about seagate promblem and there are thousand out there who have this same promblem. I know this because I have the same promblem you have.
Jan 17, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My hard disk drive does not respond or show up in My computer when plugged in.Its a seagate 1 tb with those lights in front which usually light up when connected but even that doesnt happen when i plug it...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Oct 06, 2010 | Seagate FreeAgent Pro 1TB External USB...
Seagate Freeagent not recognized, not in device manager either
OK 1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Do this with NOTHING plugged in at all. Plug back in AFTER reboot. Then it may/should all work again.
Mar 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seafate Freeagent Harddrive not recognized
is the drive shown in device manager? if not the drive is at fault.
Mar 26, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,honglake@gmail.com
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
1,540 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
