Question about HP Pavilion dv4000 Notebook
Ports usb rendered useless!
When I connect a card USB in any of the ports, the cursor is paralyzed so that I must extinguish the equipment(team), or the cartel appears with the notice: there has been exceeded the capacity of the concentrating port
  • 339 Answers
I believe that the equipment you are attaching is attempting to draw more power than the internal USB hub in the PC can deliver. If any of the equipment has an optional external power supply then try to use it to reduce the power consumption. If not, you'll probably need to get a PCI USB adapter with a higher power rating or a USB hub with an external power brick.
Posted on Jul 22, 2009
How to enable highspeed usb on neclcd1770nx monitor
On most monitors that have usb ports you have to run a usb cable from the computer to the monitor to get the usb ports to work.
If your computer is not equipped with high speed usb ports you can purchase a pci usb adapter card that can make it usb 2.0 which is considered high speed.
Try purchasing one from Tiger Direct at:
http://www.tigerdirect.com
Below is a link to one that I use which costs $9.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5265856&CatId=511
Jun 09, 2012 | Computers & Internet
When i insert the usb port in any machine it says the usb port has exceeded the power limits of it hub port
The is indication of an over storage data medium. Consider freeing up the data from the device to attain continue usage. Attempt to achieve connectivity from any available connection ports that may recognize the storage medium to allow for data freeing taking achieving regular functionalities.
Feb 02, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Nothing happens when plugged in to my laptop
This could be a number of things, lets go over the most likely.
-It is possible if you have an older laptop that you have USB 1.1 ports instead of the needed USB 2.0 port required to provide the device power. (If it has a separate "optional" power supply, use it.) Or all of the USB 2.0 ports are being used. Try unplugging all of your USB devices except for the interface and try it in different ports.
-If this isn't a problem and you have free and powered USB 2.0 ports then the next most likely culprit is bad drivers. Try uninstalling the drivers for the device (if you've installed them) and downloading the newest drivers from the M-Audio web-site and installing those.
Great choice of gear, I use quite a bit of M-Audio equipment myself and it's good quality for a good price...
Hope this helps. Thank you.
Jan 04, 2011 | M-Audio Mobilepre USB Bus-Powered Preamp...
Does my Inspiron 9400 Laptop have build in microphones?
Yes It is. You can check them either in COntrol Panel > SOund or Start > Run > DXDIAG.
WIth regards
FIXYA team
Oct 09, 2010 | Dell Inspiron 9400 Notebook
ASUS P4SDX USB Ports not recognized as USB2 HS Ports
The message comes up when a USB 2 device is connected to a slower USB 1 or 1.1 port. It is only to advise you that the devise will operate faster on a USB 2 port. If your computer has only USB 1 or 1.1 ports, you will always see the message. You can buy and install a card with USB 2 ports and install it. It will come with the USB 2 drivers. Install the card and the drivers and then connect your USB 2 device to the new hardware and you should not see the message anymore.
Good luck, And let me know ho it works out for you.
~ Spoem
Mar 30, 2009 | ASUS P4SDX Motherboard
USB ports work at 1.1; s/b 2.0
Your computer is functioning correctly.
The USB ports on your laptop are USB1 ports its pard of the hardware.
Your PCMCIA USB 2 card runs at USB 2 speed and therefore when you connect a USB 2 device to this port you will not get this USB message.
Jan 18, 2009 | Lenovo ThinkPad R51e Notebook
Upgrading two USB ports on front panel
Hi..
there is no such converter..
those pins should connected to ur mother board only...
once check ur bios settings..
or
use external usb hub..so u can get multiple usb ports that u need...
Jan 01, 2009 | HP Pavilion 761n PC Desktop
USB cable problem when transferring
could be a bent pin maybe?
I would just go out and buy a card reader so that you can read the memory card without the cord. and then you wont have to worry about it.
the card reader cost about 20 a new cord would be more.
Hope that helps,
Caleb
Jun 26, 2008 | Pentax Optio T10 Digital Camera
How to connect a motorola DCH3416 to a computer Can I connect an external Hard drive to a DCH3416 USB or SATA port so that programs record to the externl HDD, or how can I tranfer recorded program to the...
Nope...
The eSATA ports are not configured in the device's firmware, and the USB 2.0 ports are useless except for charging your iPod or powering a USB fan. If you could connect an external drive to the unit, it would be partitioned with data encryption that can only be accessed by the particular DVR that formatted the drive. You can however stream local channels to a video capture card via the firewire ports but cable channels and DVR recorded programs would be encrypted. You can thank the MPAA for the grief...
Jun 24, 2008 | Televison & Video
HP Pavilion dv4000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
