Question about Toshiba Satellite A135-S2276 Notebook
I need to get this computer to out of box condition. I have done this before but forgot what to input, can anybody help
    President:
  • 1,462 Answers
they would have given a CD along with the laptop, by booting with the cd will make your laptop as a out of box condition
NOTE: All your data would be deleted
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Jul 22, 2009
How to reuse old BPL FHR TV speakers as external speakers? my TV is in woking condition but kept idle, please anybody give suggesion
The best / correct way is maybe not the easiest way if you are not electrically minded but, funnily enough I have done this myself but in reverse so I could output the television sound to better speakers. I will explain simply but you might have to follow up with someone local for a diagram. Materials needed will be 2 x double throw, double pole switches and 2x audio female jacks. Firstly, make sure that the speakers in the television are not some weird impedance and match that of the output impedance of your external input, otherwise you are wasting your time. DIRECTIONS; - gain access to the speakers. Disconnect the input wires to one speaker and connect these to one side of the switch. The other side goes to the pos and neg of one of the audio jacks. The two centre connections on the switch go back to the speaker. Make sure the polarity is kept the same through the switch. Do the same with the other speaker. Your new audio input goes in the audio jacks. Mount the switches and jacks neatly on the side of the television. This configuration allows you to switch your speaker inputs between your television sound or your external sound. It sounds harder than it actually is. I hope this helps. Cheers Bob
Nov 14, 2016 | Televison & Video
I have just bought a Digihome 48" 4K Ultra HD Smart TV. It works fine on normal TV but through the Sky box it switches itself off has anybody any ideas??
Its input selector function is not working properly. The input selection is done by an IC inside it. If it is faulty, this type of fault might happen. Contact any service technician. If you wish to get some details; and sound in electronics; check the site linked here. Pull up older posts.
Jul 06, 2016 | Ultra Televison & Video
Can you connection satellite sound to optical input
Yes you can run optical lead from sky box to receiver in the sky box setting you need to tell it that you are using optical and on the receiver u need to bind 1 optical with hdmi input this is done though input settings hops this help
Dec 21, 2013 | Onkyo TX-SR606 Receiver
I forgot my nokia c1-01 security code. could anybody help me? here's my IMEI # 353799041632340.
I forgot my nokia c1-01 security code. could anybody help me? here's my IMEI # 357449/04/369789/6
May 13, 2012 | Nokia C101 Cell Phone
Transmission problem.
you need to buy or have your trans rebuilt this vehicle is famous for trans issues
Feb 12, 2012 | 1997 Hyundai Sonata
I WANT TO SIGN INTO FACEBOOK BUT MY COMPUTER WONT LET ME DONT KNOW IF MY EMAIL ADDRESS IS REGISTERD AS i done it through friends as they said it was free?
If you can't retrieve your password using the "Forgot Password?" button located under the password input box, you can always go into a more advanced account retrieval and click on "I can't identify my account." which is located at the bottom of the "Forgot Password" screen. From there, you should be able to put in more detailed information that will allow you to get back into your account.
May 06, 2011 | Facebook Social Network
I have a code p452 does anybody know what this means... 1999 Cadillac deville
PO 452 FUEL TANK PRESSURE SENSOR CIRCUIT LOW INPUT CONDITIONS.YOUR FTP SENSOR IS DAMAGE OR HAS FAILED.
Sep 10, 2009 | 1999 Cadillac DeVille
Connecting dvd player
You need to use a receiver and connect the units to the receiver input, Then connect the receiver output to your television's input circuit. This should allow to switch inputs to the television. This can also be done with a switching box that allows several input and output. This unit should be hooked up in the same manner with the outputs to the switch box inputs and the switch box out to the television's input circuit. the difference between the two methods is the receiver has a preamplifier that will increase weak signal levels. The switch box is a passive device and usually will not amplified the signal to the input device. You can buy amplified switch boxes if you need them. Hope this helps you with your problem.
Apr 26, 2009 | Insignia IS-PDVD10 Portable DVD Player
LE40R74BDX HDMI input stopped working
I work for sky as an engineer (not a subby)
HDCP is the encryption that is sent down when a program is transmitted. I have had this several times over the years and have found out that you need go to the manufactors web site or call them to update your telly this will sort out this problem.
I would do this sooner then later... reason I am telly you this is sky have take the Component inputs off all the sky boxes now.... The box you have is a THOMSON (have a look.... make you smile)lol this was due to people connecting there sky HD box to there pc via Component and using programs like Copy+ and extract + to copy the content.
If your box breaks down. then you are snookered if you telly is not going to accept the skyHD through a HDMI connection.
Hope this helps
Cheers
Little Dish Fitter
Mar 04, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Nokia n95 8gb
hi there, if you go to nokian95forums they have a program there called NSS and they will be able to help you get the code
Mar 01, 2009 | Nokia N95 Smartphone
Toshiba Satellite A135-S2276 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
