Question about Royal Sovereign ARP-1000EX Portable Air Conditioner
Licking water on my Royal Sovereign 1000 es
My airconditioner have a tube on the back at the bottom (is white and short)so the other day I was using the airconditioner and in two Hours when I wake up I foung water in my floor.I check the water is coming from the tube.Bot I dont know why.I never notice that and I used before and never happen.But know I want to know it maybe is missing a cap.or something.Can you help me.
There is a little hole about one inch above the the drain tube and out of it should come a rubber strap connected to a plug for the drain tube. On the far left of the control panel is a diagram of a bucket under a water drop, just below is an led that comes on when the water tank is full and needs to be emptied. I just roll mine out on the porch and pull the plug. Also, when the tank is full the unit should shut off.
Posted on Aug 29, 2009
  • 22 Answers
That is the drain tubing for the unit. If you don't want the water to come out of the tubing to drain then there should be a little door that that tube connects to that tilts out to drain to the tubing and up to drain in the collection pan. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
How do I fix the water leaking problem with my royal sovereign 1008 a/c?
that depends on where it is leaking from , as leaking is one of the things air conditioners do . since they act as dehumidifiers also . some have drain tubes some just need tilted so water runs outside.
Jul 20, 2015 | Royal Sovereign Heating & Cooling
Why does my royal sovereign portable a/c fill up with water too quickly?
its from the humidity. the higher the humidity the faster it will fill up.
Aug 14, 2014 | Royal Sovereign ARP-3012 Air Conditioner
My royal sovereign is spitting water out of exhaust
The problem you're having indicates that the may be to much downward droop in the exhaust hose and it's trapping water inside.It also may have an obstruction in it. Also, check the air intake filter and clean if necessary.
Hope this helped you and thanks for choosing FixYa.
Aug 27, 2011 | Royal Sovereign Portable Air Conditioner
My product royal sovereign arp-4012h is flooding my floor it needs to be drained... the manual says when product gets fiull of water drain plug what plug & how do i get to itt were is it located.. i...
The water drain plug is located on the rear. On the bottom left edge next to the cord keeper. You'll need a pan that will fit under the drain hole, before you unscrew the drain plug. Which has a plastic handle.
Hope this helped you. Please let me know. Thanks
Jun 11, 2011 | Royal Sovereign ARP-4012 Portable Air...
Water keeps on spilling out the back of the ARP 1000 ES Unit. I don't know how to empty the water container that must be located on the inside
The drain plug for draining accumulated water is located on the back of the unit's lower left side (as you're facing the back just to the left of the cord keeper. Unplug it, disconnect the exhaust hose and roll it to a drainage area. Unscrew the plug and let it drain. Securely replace the drain plug when draining is complete.
Jun 09, 2011 | Sovereign ARP-1000E Air Conditioner
I have an air conditioner model ARP 1000 ES. It was purchased in August 09 and now it won't come on. there is a red light that blinks right above the on and off switch. Can you tell me what could possibly...
it is possible the fuse is blown inside of furnace or air handler it should be a 3 or 5 amp car fuse also check the fault code inside of door panel there is a list of fault codes listed
Oct 01, 2009 | Royal Sovereign Heating & Cooling
A red light came on and the unit turned off
see if you can push water from the other end to see if you have something that stuck inside
Sep 08, 2009 | Royal Sovereign ARP-1008 Portable Air...
Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
Royal Sovereign ARP-1000EX Portable Air Conditioner Logo
359 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
