Question about Nikon COOLPIX P60 Digital Camera
Powers on Lens move in then out,Blank display
My nikon p60 will not turn on and cannot reset. the lens is in 'on' position, but when i hit off button, lens stays in place. i then take out good batteries and replace the batteries and same problem occurs. in other words, cannot turn cam to on position
  • 744 Answers
Hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Posted on Jul 22, 2009
Nikon L18 lens not extending..Lens error displayed
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
May 11, 2010 | Nikon COOLPIX L18 Digital Camera
Lens error comes up on the screen when I turn it on
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Apr 16, 2010 | Nikon COOLPIX P60 Digital Camera
Nikon P60-Screen is blank and lens doesn't retract.
Please remove the battery for few hrs and charge them after that replace the battery and try to power on if the problem persist then take to any service center the firmware needs to be updated or there is some short in the circuit board of the cam.
Feb 16, 2010 | Nikon COOLPIX P60 Digital Camera
Nikon P60 is not getting switched on, showing 'lens error' .
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Nov 19, 2009 | Nikon COOLPIX P60 Digital Camera
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
Lens error
try these:-
  • shake it.
Aug 16, 2009 | Nikon Coolpix S210 Digital Camera
Suggest the best brand in digital camers in 8-10 mega pixels
For the money, I think the Nikon Coolpix P60 is the best bang for your buck. I bought one myselft in August 2008 and dropped it in Feb 2009 so I must by a new camera - i am buying another P60 !
Jan 22, 2009 | Nikon COOLPIX P60 Digital Camera
Nikon coolpix3700 screen displays lens error
Hi!
I will assume that by the error message , your camera lens is stuck.
Your first option is to bring it to your dealer for repair - if it's under warranty.
If it's out of warranty and you do not wish to pay for repair, try this:
"Hit the camera on the palm of your hand a few times (hit the side of the camera , not the lens). Try it slow at first, if it does not work try to hit it harder (but gently). "
You may need to repeat the process until the lens move to it's correct position. The fix seems odd or perhaps crazy but it usually works!
I hope that helps.
Good luck and have a nice day!
Oct 02, 2008 | Nikon COOLPIX L18 Digital Camera
Hp 735 camera error e106 then it turns off
When the camera is turned on, the lens is stuck either in or out and the camera gives the error E104 , E105 , or E106 . The camera then turns itself off. Causes These errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • something is blocking the lens
  • the firmware version is old
  • the camera has been abused
  • foreign material is inside the lens or
  • the lens is loose or completely off the track
Solution Follow all of the steps listed below.
  1. Perform a power reset on the camera.
    1. Turn off the camera and remove any optional memory card.
    2. Hold the ON/OFF switch in the ON position until the HP logo displays and then disappears.
    3. The camera is now reset. When the camera is turned back on it should prompt for the date and time.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera. Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    1. Before turning the camera on, press and hold the Flash button.
    2. While the Flash button is depressed, turn on the camera. A Service Screen displays.
    3. Located at the bottom of the screen is an entry, F/W.
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately. See the HP document Recommended Firmware Updates for Photosmart 733 and 735 Digital Cameras .
Jun 23, 2008 | Cameras
Nikon COOLPIX P60 Digital Camera Logo
401 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
