Question about 2wire Computers & Internet
Home netweork Extension
I am trying to extend my home network. I just upgraded(?) to a 2wire 2701 gateway for my Bellsouth DSL service. I disabled the wireless. The desktop connects to the 2wire. Also connected to the 2wire is a netgear hdx111 powerline. The other end of the powerline is a floor below. Connected to the powerline is a netgear WNR200 (LAN side) DCHP disabled. Also in a LAN port is the Directv DVR. The WNR2000 is setup as wireless. Although this is a rats nest of connections, it mostly works. Frequently, the internet access on the desktop goes away. I am guessing I have hosed up the configurations in some way. Resetting both the 2wire and the netgear get me back to square one, but I am missing something. Is this a workable configuration? The idea behind the setup is to have a decent connection at the DVR for HD streaming and a wireless N signal in the backyard to run itunes off the upstairs stereo.
  • 284 Answers
Your right this does sound like a rats nest :) and from the available information it is impossible to tell what is wrong. It is not only about the types of devices but about the configuration on each one. Sounds like you already know that you should only have one DHCP server. But the question is do all these devices end up with an IP number in the same subnet? My advice is to sit down and draw a diagram of how you want these things to work. Install one piece at a time and make sure it works bfore you move on to the next piece. Keep it simple, don't add extra hardware into the mix if you don't really need to. If you can get everything into one sub net then make sure only one thing is acting as a router. The router is the only thing that actually connects your private network to the internet. More than one NAT router is also a bad thing. Once you get it configured the way you like use ping to check connectivity between everything.
Hope this helps
Douglessd.
Posted on Jul 22, 2009
How to install to att 2wire 2701hgb modem router
Plug power cord into back of modem and then into an electrical outlet. At this point you should see the lights on the front of the modem beginning to come on.
Check the front of the modem for a solid green DSL light. If the light is still blinking, allow a few more moments before proceeding to step 5. A blinking DSL light indicates a break in the network and will require the help of your service provider if it does not turn solid green.
Open your internet browser and type the default gateway into address bar. The default gateway will be provided by your service provider. Newer model 2Wire modems automatically direct you to the installation instructions when the browser is opened.
Click on "Run System Setup Wizard" in the lower right-hand corner. It may require the system password. This password will be provided by your service provider.
Select your timezone and click 'Next.'
Enter your ISP provided login information and click 'Next'. This should authenticate your credentials on the network and complete the installation.
Jan 02, 2013 | NetGear RangeMax Dual Band Wireless-N...
Need to find my wep key for my AT&T 2 wire 2700HG-B DSL router
The Default Wep Key is the 10 digit key located on the bottom sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simly accessing the router. I've listed the steps on how to access the router incase the Network Key on the sticker is not working.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya
Jan 31, 2011 | 2wire (2701HG-B) Wireless Router
Changing channel on router
hi....
to change wireless channel of your 2wire 2701hg youjust need to access its default gateway 192.168.1.254 type it on your address bar using internet explorer and you'll see network at a glance page. click on home networking tab at the top and look for subtab written in blue click wireless settings. you'll seewireless name and under that you'llsee wireless channel you just need to pick the channel that you want to use...
Sep 27, 2009 | 2wire 2700HG-B Router (2700HGB)
2Wire Home Portal 1100 for AT&T DSL connection problem
HI! read your posting regarding the situation that your experiencing.. If before you dont have any problem regrding your connection with out the cisco network magic. I suggest that before you install the cisco network magic. you should get the full version not the trial version, there is a limitation of setting up the trial version.. Cisco network magic is a plug and play and easy to setup if you get the full version. I dont see any problem regarding your connection with the 2wire and the linksys router, becoz you mention earlier that hime network is working and you can connect to the network and the internet..
Jul 24, 2009 | 2wire Computers & Internet
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
2Wire DSL Gateway Model 2701HG THE WIRELESS LIGHT IS NOT ON HOW DO I TURN ON THAT LIGHT
open: http://192.168.1.254
click in Home Network and then in Wireless settings / Enable
Please check this screenshots
http://support.2wire.com/?page=view&article=60
Jan 14, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 1701 HG Gateway wireless not working
There could be a lot of possibilities why you lost your connections at the same time. Could be windows update or changes had been made in your 2wire 2701 HG.Its impossible to say that your wireless adapters turned bad all at the same time.As what you observed , wireless light is off meaning your 2wire doesnt detect any wireless connection. You can try reconnecting them 1 at a time by going to your wireless connection tool or network connections.
If that didnt help, you can use your PC w/c is connected using the USB connection. Using this step, you 'l have a chance to edit and view your wireless network. For you to access your 2wire you must know what your 2wire address {default gateway}. Using your hardwired pc go to start > run > type in cmd then hit enter > on the Dos command screen type in ipconfig and hit enter> youl see your default gateway . It would look like this 192.168.1.254 for example cos sometimes it would vary depending what ISP you have, Open your fav browser and on your address bar type in your default gateway. That would lead you to your 2wire page, there youl have a chnace to view you home network. Check if your wireless encryption and you network name if everything is still the same. {Best thing is to change your wireless name or SSID. Then try to reconnect on your wireless connection for each computer and make sure you have your wireless encryption.
Hope that helps. Pls let me know asap if you need clarifications.
Cheers.
Jun 15, 2008 | Computers & Internet
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Computers & Internet Logo
232 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
