My Whirlpool double oven acts as if one or both of the doors are open. Both lights are on and if I try to start either oven, I get the door (meaning door open) code on the display. Since it thinks the door is open, I guess this is why it will not start its bake cycle. I have tried manually pushing in the switches on both doors hoping that is the problem. But that did not work. When I press the oven light button on the keypad, it beeps 3 times.
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
SOURCE: Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
SOURCE: Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
SOURCE: From "bake" mode, oven door locked, both heating elements on.
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^
