Question about Daewoo Heating & Cooling
Water is no draining from the bottom of the window unit
    Sergeant:
  • 149 Answers
The water condensed from the unit is picked up by the fan and slung against the (hot) condenser. This increases the efficiency of the unit. Therefore water should not be dripping from the unit.
Posted on Jul 22, 2009
II HAVE CODE EO ON MY HAIER ESA410M-L WINDOW
try to drain the water from the unit it should have drain holes in the back of unit on the bottom make sure they are cleaned out where they can drain the condensate water out of the unit
Sep 03, 2014 | Heating & Cooling
Draining for a Haier Window AC
no, this air conditioner is a manual drainer and is not made to drain itself
Jul 29, 2013 | Haier Heating & Cooling
I have a AW06ECB Window Air Conditioner Unit that is not draining water. It is holding it in the bottom pan. I don't see a drain pipe or hole on the bottom of this unit for it to drain either. Any...
Hello, most window units will not have a drain to remove the condensate. Instead they use the fan blade to sling the condesnate on the condenser and since the condenser is warm/hot it will evaporate it. Also, when the humidity is elevated there will be more water at the bottum of the drain pan.
Jul 10, 2011 | Samsung AW0507M Air Conditioner
Unable to locate the drainage for condensed water. I could look inside and see that water is accumulating at the bottom. Feddlers AEJ12E7AG, window unit. Thank you
Hello, most window units evaporate the condensate by having the fan blad sling the water on the condenser. Because the condenser is warm/hot it will evaporate. You shou.d be hearing a sloshing sound after the unit has benn running for a while, this indicates that the fan blade is picking up the water from the bottum of the ac.
May 31, 2011 | Fedders AEJ12E7AG Air Conditioner
Water is not draining forom my hampton bay air condiotioner. It is gurgling and you can see water inside the unit. I have tilted it more in the window there is some water dripping but there is still water...
Allot of Window units do not have a drain anymore. The condenser fan picks up the water that lays in the bottom of the unit and slings it against the condenser coil to help keep it cool. If it is not leaking water inside the house it is normal to have some water in the bottom of the unit. This is verified by not having a drain hole or hose. As an A/C service tech I didn't care for this design as allot of people thought that there was a problem when there was not. They also tend to be a little noisier as the water makes noise when it is being thrown around inside the unit. I hope this helps
Jul 06, 2010 | Heating & Cooling
Water won't drain out of the unit during high humidity
mcdevito75 here Yes they are suppose to drain from the part that is out the window, double chek the bottom of the A/C unit for a clear drain hole in the section of the unit that is outside the window.
Jun 24, 2010 | Fedders A6Y18F7BCOM Air Conditioner
Water dripping inside window opening
I would make sure the 'drain hole' is clear and not stopped up. Sounds like it could be stopped up and you have so much water in the unit it's over-flowing and coming out inside the window.
hope this helps.
p.s. one other thing - you might need to put another hole in the unit (to allow better draining). Typically these units just drip water outside and putting (with a drill) another hole in the bottom of the unit to allow better draining is easily done.
Jun 14, 2010 | Fedders A6X05F2G Wall/Window Air...
My a/c is trwonig cold water and air
The water is standing in the ac unit and not draining out.Is this a window unit?Ac on a car or truck?If it is a window unit for a house,remove ac unit from window,and take out side and if it is in a cover,remove the cover to expose the ac unit,and it`s components.Wash out the bottom of the unit to uncover all the drain holes.Get all debri out of unit.Replace the unit in the window at a good tilt(tilt it outward)so it can drain good,and not back up in your house with water.
Aug 29, 2009 | Heating & Cooling
My Air conditioner leaks water
All A/C units drain water and need a clear path to drain water.
If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree.
If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Aug 02, 2009 | Kenmore Heating & Cooling
Water not draining out the back
Humidity is where the water comes from. If humidity is low, very little if any, water.
Jun 23, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Heating & Cooling Logo
78 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Dan Webster
Dan Webster
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
