Question about Sony Handycam DCR-TRV350 Digital Camcorder
Getting an error message on lcd screen - C:32:30 with flashing triangle over bar, and bell sound. So then I can not video or playback, or even remove the tape. Please help
  • kent925 Jul 22, 2009
    Thanks tons !!!!!! It worked after I took out the large battery and waited a couple minutes. I could never find that small nickel one however.
    THANKS, Kent
    Genius:
  • 1,689 Answers
With this fix, you should be able to repair your Camcorder yourself in less than 5 minutes with no cost.
1. unplug camcorder AC cord
2. remove fat battery from back of camcorder
3. remove slim battery from under the LCD (it's the size of a nickle coin)
4. wait 2 minutes
5. plug AC into the camcorder
6. flip the camcorder into VTR mode
7. tape should automatically eject
8. viola, drink beer, be merry
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR-TRV350_tape_wont_eject_C.32.11
http://www.pechorin.com/m/2004/01/22/Error_Codes_Assistance-208526-21.html
hope this helps
Posted on Jul 22, 2009
I have a Intel D945GCCR (8) motherboard. I have downloaded audio drivers and installed it but still my sounds are disbled I am getting PCI device found message every time I start my computer. I have...
First we have to determine whether or not you have the required drivers installed in order for the operating system to communicate with your sound playback device. Following is the keyin sequence for Windows XP - The key-ins will differ somewhat for other Windows operating systems:
Click on START
Right Click on MY COMPUTER
Tnen click on PROPERTIES followed by HARDWARE and then DEVICE MANAGER.
Double click on SOUND, VIDEO and GAME CONTROLLERS
Your sound playback device (such as Avance AC 97 Audio) should be listed. And there should NOT be a yellow exclamation mark in the left margin (If there is, this is an indication that the device is not working properly - see CORRECTIVE ACTIONS below.
Double click on your sound playback device.
In the device status box you should see the statement "This device is working properly"
If you get any other messages indicating that drivers are required or need to be updated, see CORRECTIVE ACTIONS below.
If everything look OK, click on the "X" in the upper right corner to close device manager.
If everything was OK in device manager we will now see if the operating systen is sending sound to your playback device.
Click on START
Click on CONTROL PANEL
Select the Classic View (If not already displayed)
Click on SOUNDS AND AUDIO DEVICES
Double Click on AUDIO DEVICES
Click on the AUDIO tab.
In the Sound Playback dialog box your sound device (something like "AC 97 Audio") should be listed. If it is not, click on the pull-down menu and select it if you can..
If it is NOT listed, see CORRECTIVE ACTIONS below.
If it is listed, perform the following tests:
Click on the SOUNDS tab
Set the Sound Scheme to WINDOWS DEFAULT
Click on APPLY and OK
In the Program Events dialog box, click on any event that has a speaker Icon to the left of it
Underneath the Program Events dialog box you will see a small box with a triangle inside
If the triangle is black that means that the operating system has recognized your sound playback device (sound card).
Click on the triangle.
You should hear the sound through your speakers (the triangle will change to a rectangle while the sound is playing)
After the sound plays the black triangle will re-appear.
If the triangle is black and changes to a rectangle when you click on it and you DO NOT hear sound through your speakers either your speakers are plugged into the wrong jack or you have a problem with your speakers. Test or replace the speakers.
If the triange is gray that means that the operating system does not recognize your sound playback device (sound card). See CORRECTIVE ACTIONS below.
CORRECTIVE ACTIONS
If the playback device is built into the motherboard, the device may not be enabled in the BIOS. Check your BIOS settings. If your sound device is disabled, enable it and repeat this procedure.
To enter BIOS setup turn on your PC and immeadiately hold down the DEL key. (On some machines it's the F!, F2 or F10 key).
Once in BIOS setup, press the Enter key to select the first display screen, ususally titled "Standard CMOS Features". Navigate through the menus until you locate the setting for your on-board sound playback device. If it is set to "Enable" or "Auto" leave it as-is. If it is set to "Disabled." change the setting to "Enabled" or "Auto".
Follow the on-screen instructins to save yur settings and exit BIOS Setup.
If you do not have built-in sound on your motherboard you will need a sound card installed in an expansion slot on the motherboard. This card may not be present. If there is no sound card, install one and then repeat this procedure.
If you do have a playback device installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from either the motherboard or sound card manufacturer's web site. Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware problem on your motherboard or sound card.. At this point, you will require some interactive help as many questions have to be asked and answered. I recommend that you obtain this help by using FixYa Expert Chat or FixYa Expert Phone assistance. Of course you could also get help from a qualified PC technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 23, 2011 | Intel D945GCCR Motherboard
My computer audio work does not work.
Click on START
Click on START
CORRECTIVE ACTIONS
If you do have a playback device installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from either the motherboard or sound card manufacturer's web site. Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware problem on your motherboard or sound card.. At this point, you will require some help from a qualified PC technician.
Best regards,
Yavacotech
Jan 03, 2011 | Computers & Internet
My computer has no sound and reads NO AUDIO DEVICE can you please help
Click on START
Click on START
CORRECTIVE ACTIONS
Best regards,
Yavacotech
Jan 02, 2011 | Cyber Acoustics CA-4100 Computer Speakers
Have no sound how do i get my sound back
Click on START
Click on START
CORRECTIVE ACTIONS
Best regards,
Yavacotech
Dec 31, 2010 | Computers & Internet
Sound quit workong, card will not enable. Installed new card, same thing. What's up?
Click on START
Your sound playback device (Soundblaster) should be listed. And there should NOT be a yellow exclamation mark in the left margin (If there is, this is an indication that the device is not working properly - see CORRECTIVE ACTIONS below.
Click on START
In the Sound Playback dialog box your sound device should be listed. If it is not, click on the pull-down menu and select it if you can..
CORRECTIVE ACTIONS
If your playback device is installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from manufacturer's web site. For soundblaster your link is http://www.creativelabs.com/support
Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware conflict between your sound card and another device. At this point, you will require some help from a qualified PC technician.
Best regards,
Yavacotech
Dec 31, 2010 | Creative Labs Computers & Internet
No audio device
Click on START
If everything looks OK, click on the "X" in the upper right corner to close device manager.
Click on START
CORRECTIVE ACTIONS
Best regards,
Yavacotech
Dec 30, 2010 | Computers & Internet
No matter what mode I place the unit in..camera mode or playback mode...I get a yellow flashing triangle on the view screen. I can't record or do playback. Any idea what that yellow triangle represents? ...
I have the same unit and the problem your describing comes and goes from the power switch on mine. (wiggle it)
hope this helps (if it don't... get it fixed this is a cam that cant be replaced even broke they bring in 200 on ebay or did a few years ago )
Dec 14, 2010 | Sony Handycam CCD-TR517 Camcorder
C:31:23 code with flashing icon for eject,with a beeping sound
The error message indicates that the Camcorder has detected an issue that may require a power reset.
Step 1:
Try to reset the Camcorder and check if it helps to resolve the issue. Locate the RESET button behind the LCD screen of the Camcorder.
Step 2:
Turn off the Camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter.
Step 3: If still unresolved Service may requires.
Jul 17, 2009 | Sony Handycam CCD-TRV318 Camcorder
Code C:31:23 quikly flashing over a underlined triangle...HELP!
Error C:31:23 problem means that System Control is not getting Supply Reel pulse. This can be electronic or mechanical problem in camcorder.
Qualified camera tech will fix it properly.
Feb 22, 2009 | Sony Handycam CCD-TRV318 Camcorder
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
52 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
