This manufactured house is 9 yrs old and I can barely take a shower without the hot water running out. Is it an element or thermostat? I'm needing a repair/user manua? Helpl
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
SOURCE: I have a thermostat mixer shower but hot water has
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
SOURCE: Hot water does not last long.
probably has a bad heating element. May be a little limed up also. Drain the heater and replace the elements. Take a special tool to remove and replace the elements. ( fairly cheap) You can probably get the elements and parts at a good hardware store. The people at the store probably will explain to you how to replace them. Feedback please if this was of help
