Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades don't engage
I have a 42 inch Craftsmen with the 18.5 HP Briggs and Stratton engine and electric clutch. All of sudden the blades are not engaging. The mower will not start with the deck switch in the "on" position, so it seems the switch is working. I pulled the connector off the clutch and re-set it, no results. Other than that, its running fine, the drive isn't slipping. Is my clutch shot all of a sudden, or is there something else I should check first?
    President:
  • 1,865 Answers
Check the drive belt for the blades
Posted on Jul 22, 2009
I have scag rider and when I engage the blade the 2 fuse blow out?
unplug the clutch and see what happens... if it doesn't blow then you need a need clutch. if it still blows check the ignition switch and the pto switch... oh, next time include at least a model # so know what model of scag you have. multiple style electrical systems throughout the years...
Oct 20, 2013 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Starting problem
the blades stop when there isnt enough power to engage electric clutch sounds like a charging issue when the engine is running place a voltmeter to the battery there should be over 13 volts if not replace voltage regulator if that doesnt work replace stator
Jul 19, 2012 | Briggs & Stratton Briggs Stratton Intek V...
When i push the arm up to engage the blades, they don't engage
CHECK BELT, WITH MOWER OFF ! . HAVE SOMEONE MOVE HANDLE UP-DOWN AS YOU WATCH THE BELT, IT SHOULD FEEL TIGHT WHEN DECK IS LOWERED .. JAY
Sep 10, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Were does the cable hook on the deck that engages the blades
you have to give more info
If its a manual engage the lever tightens up the belt by sliding a pully against the belt
If its an electric pto it has an engadge button and that powers up the eltric pto wich inturn runs the belt
Jul 26, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower Cranks. Blade engages. When you take foot off clutch, mower cuts off
you may have a saftey switch problem on the seat
look under the seat and see if any wires are off or the switch is loose
Feb 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My Poulan 13.5 hp runs until cluch is released
remove the drive belts from the motor. if it runs ok check your pulleys. one of them might be siezed.if it still dies chk the safety switch on the gear selecter and deck engage lever.
Sep 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
419 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
