SOURCE: Sugden A48, one channel keeps
The volume control may need to be cleaned. Find a spray cleaner made for electronics, relays, ect. and spray it into the volume control from the back side of it where it connects into the circuit board. After getting the cleaner into the volume control, work it in by turning the control back and forth over and over again. Do all of this with the power unplugged from the unit. After you finish cleaning the volume control, plug it back in and turn it on and then check to see if it is working normal. Volume controls can get oxidized and dirty after a few years and require cleaning. I hope this helps, let me know if you need any further help.
Dave
SOURCE: Volume to low, need to increase , please help.
install sigmatel audio driver and it will increase ur vol
SOURCE: Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
SOURCE: i have samsunsg sgh j600. its speaker volume is too low.
i have m2710 when v attach handfree it volume is very low............
