Question about Refrigerators
Our sub zero recently started forming ice on the back panel of the lower shelf of the fridge. What do we need to do or what might be causing this problem. Thank you
  • 358 Answers
It's probably low in refrigerant ,that means there's a leak in the seal system .Sub zero refrigerators have 10 years warranty on the seal system you should call them.
Posted on Jul 22, 2009
I have a 601 R sub zero, my veggies are freezing on the shelf above the crisper
Check if Your fridge has ice or moisture on the back wall, behind that drawer, and if service light or vacuum condenser lights are on, if so : you will need to go thru this repair I show on my youtube chanel. Hope It helps. How To Replace Sub Zero Evaporator HD 1080
Jan 04, 2015 | Sub-Zero 601R
My sub zero has condensation forming inside the refrigerator
Hi - Did you take the vegetable drawers out to see if there is ice in back? If so, you might have a problem with the refrigerator seal. Defrost the ice and then check the seal of the fridge! If you don't have ice behind the drawers, still check to see if the seal is good. When you close the fridge door, it should be very hard to open if you try to re-open it quickly.
Jun 28, 2014 | Sub-Zero 650 / O Bottom Freezer...
What is causing my sub zero moled 590 , made in feb 93 to gradually warm up?
yeah vacuuming behind the fridge is a good start this will help the fridge preform better as when dust builds up on the condenser it will cause the discharge to be hotter than it should be making the cooling in the case not as efficient. i would start by removing the pannel in the fridge and seeing if any ice is on the evaporator
May 22, 2014 | Sub-Zero Bottom Freezer Refrigerator
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Ice on back wall of fridge
The ice forming on the back wall of your sub zero indicates that you have a part failure. I don't recall exactly what the part is but as soon as you mention your symptoms to a sub zero repairman he'll know your problem. It's an easy fix. Everything comes out of the fridge, takes the inside back wall off and replaces the part. Not an inexpensive repair, however the part is guaranteed for 5 years so you may have an opportunity to have it replaced under warranty as I did.
Sep 07, 2009 | Sub-Zero 632 / S
1983 sub zero 241rfd with extensive ice on fridge coils and frost back of fridge drawers. Is this fridge frost free or do we need to defrost? We have defrosted by turning off fridge, but wondering what the...
sounds like a thermostat and a timer to me
start off with a thermostat if that doesnt work buy a timer
it's a bit expensive like 100.00 buy if you like the fridge or cant afford a new 1
thermo $10- $30
timer 30-70 try to buy recycled parts that are tested there cheeper
Jul 27, 2009 | Refrigerators
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero Fridge not cooling and ice forming
You do have a leak and it will be in the evaporator. So call a factory authorized company and have it replaced.The warranty of a Sub Zero sealed system is full parts and labor for years 1-5 and parts only in year 6-12. Sub Zero expects a lot of their service companies so it behooves you to call one. To find an authorized company go to http://www.subzero.com/locator/locator.aspx?type=0&zip= or call 800-222-7820
May 31, 2008 | Sub-Zero 601R
Refrigerators Logo
180 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
